Monitor 7 stands
Mike Kozak
I am looking for stands for my Monitor 7c speakers. I would like to get the short ones like the original Polk sold with their speakers.
Post edited by Mike Kozak on
Good luck, they're pretty desirable. You're better off making a set. Directions have been posted on here before."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I was thinking the same thing as Face. If you have the ability you might want to consider making them yourself. Do a search on the forum and you might find a diy thread for them. Either way good luck on your search.
I believe Doro posted it, that may help you find it."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks, I have the speakers on 15" high stands, is that too high for them?
I like the tweeter at ear level, or at least angled towards my ears. It's whatever sounds good to you. I believe I use 1' stands angled slightly back."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I got a brand new pair of Target MR28 Black.
$300 shipped
