DWS500 & power
soco
soco Posts: 1
Hi, I looking for some advice about 120v power in general, but, specifically for my sub.
Right now, the equipment is only protected by a mid-price strip all located at the display, but there is no room for the sub.
There are two other places I can put the sub, but I not sure about what circuit to plug it into.
The closest circuits to location 1 are:
1. 15amp General with a couple of flouro ballasts & a small fridge.
2. 20 amp dedicated split as follows:
2a.1500KW UPS with computer & small electronics
2b.1500KW UPS full sine wave with computer & monitor.
The closet circuit to the 2nd location is:
1. A 20amp dedicated circuit for a 7.5 amp window air conditioner.
Are any of these acceptable to power the sub?
Post edited by soco on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2008
    I would use the closest outlet. If you have no noise or hum, you're all set. I'd turn the air off when listening anyways, so it would be a dedicated sub outlet at that point.
