Why so much CSi3 hating?
vivarey
vivarey Posts: 24
edited January 2008 in Speakers
LOL maybe I exaggerated on the title, but it seems like the CSi3 is the ugly stepchild of the RTi series, at least on this forum.
I recently purchased a pair of RTi8s for a GREAT deal, and because the CSi5 is nowhere to be found (save for second hand supplies) -- is the CSi3 THAT much worse of a choice? Will it significantly impair my overall experience? I went from being excited about my new system to earnestly concerned. And now I don't know what to do. :(
Post edited by vivarey on
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    It's still a very good speaker. The 5 is just much better,dialogue is clearer and the drivers are the same size as the 8's. Don't sweat it you'll be fine it's just that you will want to upgrade it. Enjoy the 3 and keep your eye out for a 5 when one becomes available. Then sell your 3 and you probably wont be out much. No worries!!!
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited January 2008
    vivarey wrote: »
    I have a CSi3 with my RTi4s (front and back) - and for a medium sized, budget minded HT, the CSi3 is a good value and I'm quite happy with its performance.
    I'm not saying that it is 'high end' - but my HT experience has been positive.
    With RTi8s, it may not be the best match so keep your options open.
    Erik
  • BeRad
    BeRad Posts: 736
    edited January 2008
    I have the csi3 with rti 8's and absolutely love it. I have never heard the csi5 and am not sure if I ever will because I am too satisfied with what I have now.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2008
    vivarey wrote: »
    It's the bigger must be better scenario. It's happened as long as Polk has offered 2 center channels in the RT lineup. In the 90's I had an all RT setup (2nd gen) and traded my CS400 for a CS300 - I preferred the smaller drivers - the dialouge and voicing was more believable, I found the 400 'chesty' and not as clear and articulate.
    Don't get me wrong, to each his own, and I'm sure the 5 is a fine speaker but the 3 is every bit as good, it just won't play as deep or as loud - and it certainly has a spot in any RTi home theater setup.
    Cheers,
    Russ
  • nm4710
    nm4710 Posts: 97
    edited January 2008
    As the owner of both a CSi3 and CSi5 I can tell you that there honestly isn't much difference. If you run the center as full range the CSi5 does go a little deeper with male voices. As far as volume, both reach ear-bleeding levels. As far as dialogue it sounds similar on both. Don't let everyone bully you into thinking you have to get a CSi5. I bought mine after the CSi3 and I wish I had just gotten another CSi3. The extra $150 could have been better used somewhere else.
  • shimey013
    shimey013 Posts: 79
    edited January 2008
    Me being a total speaker noob, I just bought the RTi8's, and all i keep hearing is about the Csi5, since its impossible to find, im assuming the the CSi A6 is the newer comparable model (Sadly there isnt a place local that sells these) anyway, I was actually thinking about buying the CSi3 if i cant find the CSi5...Because is it really worth the extra $250 for the Csi A6 if i cant find the CSi5 or should I just pick up a CSi3, I have the ONK 705 reciever too.
  • BeRad
    BeRad Posts: 736
    edited January 2008
    amazon has the csi3 in cherry for 130. I guess I had good timing on my system since they no longer have the thing in black or the psw505 for that matter. (at least not directly from amazon with free shipping and all!)
  • devani
    devani Posts: 1,497
    edited January 2008
    I am deciding on 3 or 5 too...hard to decide because I live near tweeters...less than hour's drive
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    If you can get a 5 at a good price then do it,otherwise the 3 at $130 is a helluva speak. I have owned both and the 5 is much better IMHO.Maybe if I had the 3 hooked up to the Adcom I'd feel different about it.
    P.S. I had the 5 before the Adcom,also.
  • Windwalker
    Windwalker Posts: 46
    edited January 2008
    Very Happy with my 3 that I found on CLs for 50
    Does ALL I need, sounds sweet with my 5jr
    stepped up from cs100, so guess anything was moving in the right direction
    Some of the worst wrongs get righted on three cords
  • nodeuces
    nodeuces Posts: 96
    edited January 2008
    There is a noticeable difference. Especially in the lower tones of voices. I got one from Tweeter. I'm curious if all the CSi3 haters who says "the CSi5 has the same size speakers as the 6s 8s 10s" would recommend a CSi3 with with RTi12s...since they have the same speaker size.
    TV: Hitachi P42H401
    DVD Player: Sony Playsation 3
    XM Tuner: polkaudio XRt12 Reference Tuner *SOLD*
    Console: Nintendo Wii
    Cable: Tivo Series II DVR *SOLD*
    Receiver: Onkyo 705
    Amps: (3) Outlaw M200
    Center: polkaudio CSi5 *SOLD*
    Fronts: polkaudio RTi12s *SOLD*
    Sides: polkaudio RT8s *SOLD*
    Rears: polkaudio RT8s *SOLD*
    Sub: Invisible :(
  • Willow
    Willow Posts: 11,222
    edited January 2008
    I don't mind my csi3, keep in mind it's hooked up to my OutlawM200. ;)
    200w is nice to have on it for sure
  • cmy330go
    cmy330go Posts: 2,341
    edited January 2008
    I spent a lot of time selling both the Csi centers. The CSi3 is an outstanding center....until you hear the CSi5. In A/B comparisons it is a very noticeable difference. Don't get me wrong...Like I said the 3 is a great center. At it's price point nothing else we had would touch it. BUT....The 5 is blatantly better.
    It was common for even budget minded customers to hold off 'till they had enough money to get a 5.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Gizmo99
    Gizmo99 Posts: 169
    edited January 2008
    I wish the LSIC was as big as the CSI5...
    Receiver: Onkyo TX-SR805
    Amp: Emotiva XPA-5
    Front: LSI15
    Center: LSIC
    Sourround: FxiA4
    Rear: Fxi3
    Sub: Bic H100
    TV: Sony 52' XBR4
    "The more time you spend researching here, the less money you will have" :D
  • vivarey
    vivarey Posts: 24
    edited January 2008
    devani wrote: »
    You should call them first and make sure they even have it before you drive over.
  • shimey013
    shimey013 Posts: 79
    edited January 2008
    I dont live near a tweeter, so im debating if i want to spend the extra money on the A6 or save some money and get the Csi3....since it seems like finding the 5 is IMPOSSIBLE... anyway, in your honest opinion what you think is the Csi3 a good buy or should i fork out the money and get the A6??
  • vivarey
    vivarey Posts: 24
    edited January 2008
    shimey013 wrote: »
    Personally speaking I don't think I can justify an extra $250 for 1 speaker -- even if the performance is better. I'm on a budget and that would just throw everything out of whack. And it isn't "until death do you part" when it comes to speakers. You can upgrade in the future.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    shimey013 wrote: »
    Please note post #2.
  • shimey013
    shimey013 Posts: 79
    edited January 2008
    daboyz wrote: »
    Pretty much, in 2 weeks if a CSi5 isnt up for sale, im more then likely getting a CSi3, since i cant really see spending the extra money on the A6....If i had a bigger room and maybe lived in a house instead of connecting townhouse, id probably spend more money, but as of now it looks like im going with the CSi3, like said i can always upgrade if one pops up.
