OK DVD gurus..yet another question...
steveinaz
What audio settings should I select on my Blu ray for the best 2-channel sound from digital coax output to my Benchmark DAC1. Would it be "PCM" and "Do not down convert" for example? Or Bitstream???
Post edited by steveinaz on
You'd get the best sound by getting three more speakers
He'll get more speakers when he grows more ears..
PCM would be the best sound.Shoot the jumper.....................BALLIN.............!!!!!
I could be wrong on this, but if you select PCM won't the DVD then be doing the DAC conversion? Does the "do not down convert" deal with whether or not 5.1 is converted to 2 channel inside the player?
I think bitstream is the way to go. But again, I could be wrong
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Yes,this will ensure that the DAC is getting highest resolution data from the player.would it be "PCM" and "Do not down convert"Testing
Testing
Testing -
Polkmaniac wrote: »He'll get more speakers when he grows more ears..
If he invites over 1.5 friends, he will be there.....Mains.............Polk LSi15 (Cherry)
Thanks all. The Panasonic had re-adjusted itself to PCM/No down conversion. I guess it senses the digital connection some how?
oh, and btw 2-Channel forever that is all....:DSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Excellent, good to see its working out. I run 2 channel in the bedroom with HD DVD setup.Shoot the jumper.....................BALLIN.............!!!!!
