Shocking!!!
mangata572
I went to make an adjustment on my Anthem AMV30 the other day and got a small static electricity shock from touching the metal face plate. The unit shut it's self down. I waited a few minutes then turned it back on, everything works fine.
The next day, remembering what had happened, and thought I would ground any static electricity by first touching the metal face on a Carver amp that is on a shelf with other equipment, but not hooked up to anything. ZAP!!! I got static shock of a lifetime! The Anthem shut it's self down again.
I waited just like the night before, turned it on and everything works, but the sound from my DVD player (video works fine)! It was sitting on top of the Carver amp. The Anthem is now showing no signal from the coaxial cable, so I switched to a optical cable. Still no sound, or signal on the Anthem.
Two questions; 1. has this happened to anyone else? 2. If (or should) I use the chassis ground screw on the back of the Anthem to a ground, will this help with static electricity discharge when I touch metal faceplates?
Sorry for the long post, but I feel now I feel like touching something metal in another room before touching my gear. Help!
Post edited by mangata572 on
You sure it was static?
I doubt a ground lead will help, your components are already grounded to the wall socket through the power cords. Unless your using a cheater plug... -
No cheater plug. I am now touching a metal screw on a light switch before touching the gear, sometimes getting a mild shock, but eliminating any built up static.
mangata572 wrote: »No cheater plug. I am now touching a metal screw on a light switch before touching the gear, sometimes getting a mild shock, but eliminating any built up static.
I usually ground out my personal built up static before touching my live gear. -
I had a similar static issue with my preamp ,every time I changed source or volume I would get nailed.It only happened in the winter (drier air )and when I had carpet.It has'nt happened since I changed to a wood floor.:DTesting
Testing
Testing -
If you have a wool rug,thats not too good as wool builds up static like crazy.Make sure your cables are not touching the carpet also.Grab your nuts before touching your gear.HT SYSTEM-
lsi 9's -
Could it be a slight voltage build up on the chassis? And discharging when you touche?
Move the peice to another part of the room and see what happens..Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
You could also try using a static strap wristband, maybe it will help.Shoot the jumper.....................BALLIN.............!!!!!
Wear latex gloves! Helps keep fingerprints off your gear to boot.
j/k -
speakergeek wrote: »
Ok..****...touch....sowwwyMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Use the remote..........HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Take your shoes AND socks off...problem solved. The carpet feels nice between your toes, and you wont build up a charge walking around.The first rule of Fight Club is you don't talk about Fight Club
Could also install a humidifier in your house to run over the winter....Mains.............Polk LSi15 (Cherry)
