Shocking!!!
mangata572
mangata572 Posts: 52
edited January 2008 in Electronics
I went to make an adjustment on my Anthem AMV30 the other day and got a small static electricity shock from touching the metal face plate. The unit shut it's self down. I waited a few minutes then turned it back on, everything works fine.
The next day, remembering what had happened, and thought I would ground any static electricity by first touching the metal face on a Carver amp that is on a shelf with other equipment, but not hooked up to anything. ZAP!!! I got static shock of a lifetime! The Anthem shut it's self down again.
I waited just like the night before, turned it on and everything works, but the sound from my DVD player (video works fine)! It was sitting on top of the Carver amp. The Anthem is now showing no signal from the coaxial cable, so I switched to a optical cable. Still no sound, or signal on the Anthem.
Two questions; 1. has this happened to anyone else? 2. If (or should) I use the chassis ground screw on the back of the Anthem to a ground, will this help with static electricity discharge when I touch metal faceplates?
Sorry for the long post, but I feel now I feel like touching something metal in another room before touching my gear. Help!
Post edited by mangata572 on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited January 2008
    You sure it was static?
    I doubt a ground lead will help, your components are already grounded to the wall socket through the power cords. Unless your using a cheater plug...
  • mangata572
    edited January 2008
    No cheater plug. I am now touching a metal screw on a light switch before touching the gear, sometimes getting a mild shock, but eliminating any built up static.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    mangata572 wrote: »
    I usually ground out my personal built up static before touching my live gear.
  • Systems
    Systems Posts: 14,873
    edited January 2008
    I had a similar static issue with my preamp ,every time I changed source or volume I would get nailed.It only happened in the winter (drier air )and when I had carpet.It has'nt happened since I changed to a wood floor.:D
    Testing
    Testing
    Testing
    tonyb Posts: 33,069
    edited January 2008
    If you have a wool rug,thats not too good as wool builds up static like crazy.Make sure your cables are not touching the carpet also.Grab your nuts before touching your gear.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Could it be a slight voltage build up on the chassis? And discharging when you touche?
    Move the peice to another part of the room and see what happens..
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Sherardp
    Sherardp Posts: 8,038
    edited January 2008
    You could also try using a static strap wristband, maybe it will help.
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
    Wear latex gloves! Helps keep fingerprints off your gear to boot.
    j/k
  • speakergeek
    speakergeek Posts: 555
    edited January 2008
    jakelm wrote: »
    ...when you touche?
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Ok..****...touch....sowwwy
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2008
    Use the remote..........
  • shadowofnight
    shadowofnight Posts: 2,735
    edited January 2008
    Take your shoes AND socks off...problem solved. The carpet feels nice between your toes, and you wont build up a charge walking around.
    The first rule of Fight Club is you don't talk about Fight Club
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    Could also install a humidifier in your house to run over the winter....
