12v Trigger
gwh
gwh Posts: 1,451
edited January 2008 in Electronics
Emotiva LMC-1 (pre)
The Control Output is current limited to 120mA
Sonance Sonamp 5150 (amp)
Remote Trigger: 5-24 VDC / AC @ 5mA.
Given the above info is the pre capable of turning the amp on and off?
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • Systems
    Systems Posts: 14,873
    edited January 2008
    Yep should work fine asssuming the pre can output at least 5 volts.
    Testing
    Testing
    Testing
  • gwh
    gwh Posts: 1,451
    edited January 2008
    Okay it does work.... The end going to the amp needed to be pulled out of the port a little to work....Maybe the end is too long or something.
    Thanks for the reply.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • Systems
    edited January 2008
    Yes it is a nice convenience feature.
    Testing
    Testing
    Testing
