Sub?
Any subwoofers that plays down to down to 16Hz, 120dB SPL at 30Hz .
Any recommendations?
Post edited by har_navalta on
  • dave shepard
    dave shepard Posts: 1,334
    edited March 2003
    Look in the speaker section and read the Dr.'s and HBOMB's posts on the SVS subs very impressive almost a must read even if not looking for a new sub. very impressive in-deed.
    Good luck
    Dave
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited March 2003
    Har -
    1) what size room (ft3)
    2) how many permanent openings to other rooms
    3) will the sub be corner loaded
    4) how far from the sub is the key listening position
    5) what is your budget
    Ed Mullen ([email protected])
    SVS
  • mantis
    mantis Posts: 16,890
    edited March 2003
    Originally posted by Dr. Spec
    Har -
    Exaclty.
    DUDE?120db,you plan on being in the room when using it this loud or just looking for capabilities?
    I'll give you some subs to go look into that play loud and low.One word Velodyne,HGS series.If your looking used,F series was impressive.
    Dan
  • har_navalta
    har_navalta Posts: 957
    edited March 2003
    I am just looking for a sub that has much, much better or equivalent to the SRT sub...
    Here is the specs. of SRT sub.
    SRT Subwoofer Specifications:
    High Velocity Compression Drive band-pass enclosure
    Weight: 87 lbs, 39.47 kg.
    Size: 31 1/2" H x 12" W (at top of cabinet), 14 1/8" W (at base) x 23 1/4" D. Metric: 80cm H x 30.46cm W (at top of cabinet), 35.89cm W (at base) x 59.02cm D
    One SW1080 10" woofer each cabinet
    One SW1081 10" woofer each cabinet
    High flow, low turbulence Power Port
    Built-In Amplifier Power: 300 Watts RMS
    Dual voltage operation - 115V or 230V, switchable
    "Auto On / Off" circuit
    Frequency Response: -6dB at 16Hz (in 3,500 cubic foot room) to -3dB at 90Hz
    Maximum Output: approx. 120dB SPL above 30Hz (pair of
    woofers in 3,500 cubic foot room at 1 meter)
    Variable height feet with removable spikes
    This sub plays down to 16Hz, 120dB SPL at 30Hz .
    Impressive!!!
    Har
  • Dr. Spec
    edited March 2003
    http://www.svsubwoofers.com/subs_b4_plus.htm
    http://www.acoustic-visions.com/everest.htm
    Either of these subs will leave the SRT choking in the dust.
    SVS
