A Doubt..
Quiet
Quiet Posts: 1
edited January 2008 in Car Audio & Electronics
Ok, I have 1997 Sportage. I removed the old after market radio and put in a radio/cd player. Evrything worked fine until i turned my car off. I tried starting my car and it doesnt wan't to start, my locks, lock and unlock only if my key is in the ignition and my light inside the car doesnt work. What can be wrong with my car???????
:confused:
Post edited by Quiet on
  • exalted512
    exalted512 Posts: 10,734
    edited January 2008
    I would start with checking fuses and the voltage of your battery. Could be something as simple as a dead battery.
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2008
    Yeah, sounds like a battery to me as well. Could be something as simple as you didnt put the negative cable back on securely after you installed the head unit. Id start there first.
