RTA15rdo's, and caps
ben62670
ben62670 Posts: 15,969
edited January 2008 in DIY, Mods & Tweaks
Well I was doing inventory of parts here, and cleaning a bit. I had some MW6502 woofers in the RTA15TL's with a different inductor. I wanted 4ohm RTA's. Well Now I don't want 4 ohms. I want 8. So I was changing the woofers out, and looked at the XO. I wasn't planning on doing an upgrade for a while, but I saw a 12uf, 20uf, 2ohm resistor, and I had the caps, resistors, and some RDO's kicking around. I ended up using Morels for my custom SDA's, but the RTA15TL's have a beveled cut out for the tweeter. So in go the RDO's. I wanted to use the Dayton 12uf, but they are longer than the Solen's. So I did it all in Solen's with a Mill's 12w 2ohms. I am rewiring my big ones now so I guess I'll get an ear on them later:)
Ben
Post edited by ben62670 on
  • ben62670
    edited January 2008
    Ouch. I thought they were going to be enjoyable to listen to seeing the caps were broke in. I forgot about those RDO's being new. I wish I could put it on repeat, crank it ,and leave!
    Ben
  • ben62670
    edited January 2008
    Here is a pic. I might change out the resistor for a larger value to tame the tweeter if it doesn't chill out soon! I can always change it back:)
    DSCN0872.jpg?t=1200495885
    Ben
    heiney9 Posts: 25,396
    edited January 2008
    ben62670 wrote: »
    You of all people should be a little bit more patient and let the damn tweeters burn in, silly :D. It took quite awhile for my 5B's to finally sound good.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    But I want it NOW, NOW, NOW, NOW, NOW!!!!!!!!!
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Give the RDO's a few more days, then ditch them if they dont work out. Go Peerless. Peerless sound great right out of the box, no breaking in, no crying for days.. Screw those RDO's....lol
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited January 2008
    I wish I could just crank them for a weekend, and come back:) My buddy, and I were just cranking some Nickel Back, and he says "what is that sound coming from that speaker?". It comes, and goes. Like you guys said, and I know better. IT just takes time!
    Ben
  • ben62670
    edited January 2008
    I had them cranked for a while. I was listening, and one just "broke", and in 10 minutes more the other "broke". They mellowed right out. I wasn't going to crazy on them. About 100 watts each, and they all of a sudden just smoothed out. Anyone have a similar experience. I know they are not broke in all the way, but they sound a lot better! I don't want to ram ice picks in my ears anymore:)
    Ben
  • Polk addict
    Polk addict Posts: 558
    edited January 2008
    How many watts do they go up to?
    Chiranth
    hoosier21 wrote:
    Cobra + SDA's = dead amps laying all around.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    ben62670 wrote: »
    I have heard them right out of the box. They were not as bad as you discribed. I wonder if Polk changed something about them. I;m glad they are working out for you.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    The RDO's? Probably 30-40 watts.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited January 2008
    jakelm wrote: »
    I have just been spoiled by my Morels. I have never had the opportunity to get my ears on some peerless. I may at some time get some for a small tube rig. Maybe build a mini SDA2b-peerless.
    Ben
  • ben62670
    edited January 2008
    The RTA15's can handle 250 watts max. The tweeter never sees this much power.
    http://www.polksda.com/pdfs/RTA_TL_Sales_Brochure.pdf
    Ben
  • ben62670
    edited January 2008
    Sounding better.
    Ipod Tube/integrated
    Silver speaker wire's, and IC's
    Still a little hot.
    I have been playing with my old JVC Receiver, and removed a few parts. I am thinking about building a tube/integrated with some nuts.
    DSCN0913.jpg?t=1201231700
    DSCN0900.jpg?t=1201231678
    DSCN0914.jpg?t=1201231256
    DSCN0918.jpg?t=1201231306
    DSCN0915.jpg?t=1201231352
    It worked perfectly fine. I had it since 1987. It was over a grand for the system, and it had sentimental value, but I hooked it up, and what I thought was a good stereo 130wpc receiver was just not there for me. To edgy. 42vdc per rail can yeild a fairly decent tube/integrated:D
    Ben
  • Systems
    Systems Posts: 14,873
    edited January 2008
    ben62670 wrote: »
    the problem will be finding tubes that can work on only 42 volts of plate voltage.:D
    Testing
    Testing
    Testing
  • ben62670
    edited January 2008
    GV#27 wrote: »
    I have been finding that out. I did however find a guy who had a schematic of a tube line driver for 85vdc, and I can sum that transformer for (got lucky) 85vdc:) I was going to separate the 2 secondaries on the tranny for 42 each, but will be able to rectify the 2 hot secondaries, and use the center tap as a ground.
    Ben
