Connecting LOC to two amps?
roscoe1972
I am connecting an Amp for the fronts and another for a sub to the stock HU. The amp for the fronts has "passthrough" RCA connections to daisy chain other amps.
Question: Should I daisy chain the two amps, using only one set of RCAs from the HU? OR Should I use two sets of RCAs, one for each amp?
If I should use two sets, do I connect one to the front spkr. output wires and one to the back wires for the sub (I'm not using the backs)?
Also, If I am to use only ONE set, won't that be a very weak signal for two amps?
2005 Mazda3 Hatchback, regular 6 speaker package
Harman Kardon 245
Polk CSi30
Polk RTi6
Polk RTi4 (2)
Polk R150 (2)
Infinity Entra Three (2)
JBL PB10 Sub
JBL 500 (2)
Polk CSi30
Polk RTi6
Polk RTi4 (2)
Polk R150 (2)
JBL PB10 Sub
JBL 500 (2)
Post edited by roscoe1972 on
I would personally use the pass through from the first amp. less wiring for you and less hassle. Either way you go, the results will probably be the same. I actually was worried about losing signal like that by splitting up a LoC...my LoC goes into an EQ and 3 RCAs come out and i have no signal issues
Use the extra set of RCA's.
The outputs on the amp will work but you lose the ability to fade between the 2.polkaudio sound quality competitor since 2005
