Confused about wiring
ryanjoachim
I have NO clue how to wire up my new speakers.
I have the Onkyo 605B
RTi10 x4
DSW Pro 600
CSi3
Firstly...am I just blind or is there no place on the receiver to hook up speaker wire for the Sub?
Also...why is there 4 spots for speaker wire at each location on the receiver?
I'm sorry for these "basic" questions...but I really am an idiot when it comes to Home Theaters.
RTi10 x4
DSW Pro 600
CSi3
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
The sub should be connected to the "sub pre-out" on the receiver, or using the "Polk Way" which can be found elsewhere on this site.
As to having 4 posts on each speaker, that is to facilitate bi-wiring or bi-amping. Those are advanced functions that some people use to get extra performance out of their speakers. You can just connect the speaker wires to either the top or bottom posts (I use the bottom).Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
the subwoofer gets hooked up to the LFE or subwoofer output with an RCA cable... it will be on the back usually next to your pre amp outputs... subwoofers do not hook up with speaker cable. well usually not anyways.PolkFest 2012, who's going>?
here you go. here is a picture of the back of your Onkyo receiver.. plug in a RCA cable from the sub woofer pre out. next to the zone 2 speakers... to your subwoofer RCA input.. which subwoofer do you have.?PolkFest 2012, who's going>?
ryanjoachim wrote: »I
The four spots at each location on the receiver are because you need a + and a - speaker wire for both the left and right speakers. For example, you have a front left and a front right speaker, each speaker has two wires going to it. -
DSW Pro 600 is my sub"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
Now, if normally subs don't use speaker wire to connect to the receiver, then what are the Speaker In and Out spots for on the Polk DSW Pro 600?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
You don't have to use the speaker in and out on the sub, it's just another way of hooking it up.
To keep things simple, I use a RCA type cable from my sub out on the back of my receiver to the LFE in on my sub."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Couple more questions...
What are the Zone 2 line out and Zone 2 Speaker used for?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Now, seeing as how I can use an RCA cable for the subwoofer, would I also be able to just use a Digital Coaxial cable from the "white" port on the sub to the purple one on the receiver?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
Just curious, but didn't your receiver, subwoofer and speakers come with a manual???? If not, you can find them at the following locations:
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
http://www.polkaudio.com/homeaudio/products/individual/subwoofers/dswpro600/
http://www.polkaudio.com/homeaudio/products/individual/floorstanding/rti10/ -
Yes, digital coax and subwoofer cables are both 75ohm, it should work fine.
SUBWOOFER on the back of the receiver, LFE IN on the back of the sub."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Awesome!
Hopefully my last question:
With this setup, should my last 2 RTi10's go on each side of the couch facing the TV?
Or should they be angled in towards the listeners?
Or can they be behind the couch without losing a lot of sound?"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
And thanks for the links MHayes! I haven't received the...receiver yet. I was asking these questions now because I KNEW that even with the manual I would have to ask them anyways.
Also, I wanted to be prepared when everything was ready to put together."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
:rolleyes:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
