Confused about wiring
ryanjoachim
ryanjoachim Posts: 2,046
edited January 2008 in Speakers
I have NO clue how to wire up my new speakers.
I have the Onkyo 605B
RTi10 x4
DSW Pro 600
CSi3
Firstly...am I just blind or is there no place on the receiver to hook up speaker wire for the Sub?
Also...why is there 4 spots for speaker wire at each location on the receiver?
I'm sorry for these "basic" questions...but I really am an idiot when it comes to Home Theaters.
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • tcrossma
    tcrossma Posts: 1,301
    edited January 2008
    The sub should be connected to the "sub pre-out" on the receiver, or using the "Polk Way" which can be found elsewhere on this site.
    As to having 4 posts on each speaker, that is to facilitate bi-wiring or bi-amping. Those are advanced functions that some people use to get extra performance out of their speakers. You can just connect the speaker wires to either the top or bottom posts (I use the bottom).
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • danger boy
    danger boy Posts: 15,722
    edited January 2008
    the subwoofer gets hooked up to the LFE or subwoofer output with an RCA cable... it will be on the back usually next to your pre amp outputs... subwoofers do not hook up with speaker cable. well usually not anyways.
    PolkFest 2012, who's going>?
  • danger boy
    edited January 2008
    here you go. here is a picture of the back of your Onkyo receiver.. plug in a RCA cable from the sub woofer pre out. next to the zone 2 speakers... to your subwoofer RCA input.. which subwoofer do you have.?
  • Polkitup2
    Polkitup2 Posts: 1,641
    edited January 2008
    I
    The four spots at each location on the receiver are because you need a + and a - speaker wire for both the left and right speakers. For example, you have a front left and a front right speaker, each speaker has two wires going to it.
  • ryanjoachim
    edited January 2008
    DSW Pro 600 is my sub
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • ryanjoachim
    edited January 2008
    Now, if normally subs don't use speaker wire to connect to the receiver, then what are the Speaker In and Out spots for on the Polk DSW Pro 600?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • Face
    Face Posts: 14,340
    edited January 2008
    You don't have to use the speaker in and out on the sub, it's just another way of hooking it up.
    To keep things simple, I use a RCA type cable from my sub out on the back of my receiver to the LFE in on my sub.
  • ryanjoachim
    edited January 2008
    Couple more questions...
    What are the Zone 2 line out and Zone 2 Speaker used for?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • ryanjoachim
    edited January 2008
    Now, seeing as how I can use an RCA cable for the subwoofer, would I also be able to just use a Digital Coaxial cable from the "white" port on the sub to the purple one on the receiver?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • MHayes
    MHayes Posts: 42
    edited January 2008
  • Face
    Face Posts: 14,340
    edited January 2008
    Yes, digital coax and subwoofer cables are both 75ohm, it should work fine.
    SUBWOOFER on the back of the receiver, LFE IN on the back of the sub.
  • ryanjoachim
    edited January 2008
    Awesome!
    Hopefully my last question:
    With this setup, should my last 2 RTi10's go on each side of the couch facing the TV?
    Or should they be angled in towards the listeners?
    Or can they be behind the couch without losing a lot of sound?
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • ryanjoachim
    edited January 2008
    And thanks for the links MHayes! I haven't received the...receiver yet. I was asking these questions now because I KNEW that even with the manual I would have to ask them anyways.
    Also, I wanted to be prepared when everything was ready to put together.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • Face
    Face Posts: 14,340
    edited January 2008
    :rolleyes:
