*Crazy Doro's Audio Blowout 2008*
dorokusai
dorokusai Posts: 25,576
edited January 2008 in For Sale (FS) Classifieds
NAD C372 Integrated Amplifier - 9/10 - Grey - *SOLD* to Bill Ayotte
This is a beast of an integrated and completely overkill for my computer rig. It's the largest integrated NAD makes, aside from the uber expensive Master Series and you'll know it when you see it. It's a wonderful piece of gear.
I'm the original owner and the unit has low hours. All connections have been cleaned with CAIG products and it's packed to withstand an atomic blast.
2 x 150W Minimum Continuous Power into 4/8 ohms
220W, 340W, 460W IHF Dynamic Power into 8, 4 and 2 ohms, respectively
PowerDrive™
High Current Holmgren™ Toroidal Power Transformer
Bridgeable to 400W Mono (8 ohms)
A/B Speaker outputs with remote switching
7 Line Inputs, including Two Tape In/Outs
Main-amp input & 2 pre-amp outputs
Bass and Treble Controls with Tone Defeat Switch
Relay Input Switching
All Discrete Circuitry
Gold plated RCA Connectors
Short signal path from input to output
NAD Soft Clipping™
Headphone socket
IEC Detachable Power Cable
12V Trigger Output
IR Input/Output
NAD SR-5 Full System Remote Control
Ventilation Notice from NAD
In other words, don't set other gear on top of it....period. It's biased pretty high and generates a good amount of heat.
Includes: Original box, packaging, remote control, power cord and user manual.
Musical Fidelity X-Can v3.0 Headphone Amplifier - 7/10 - Silver/Black - *SOLD* to Polkmaniac
I've owned a few of the X series components over the years, starting with a v1.0 soda can style amplifier way back in the day. It's a perfect headphone amp that has no issues driving Sennheiser, AKG or Grado headphones. It's got a nice warm sound due to the tube based design which is patterned on the Tri-Vista circuit.
It has some scratches on top and a very small ding in the faceplate. It's superficial stuff but enough to rate it 7/10 on Audiogon. I've touched up the chassis scratches and I honestly don't think you will even mind.
If you buy both the amp and AKG headphones....I'll make you a deal.
Includes: Original box, wall wart and user manual.
AKG Reference K701 Headphones - 9/10 - White/Grey - *SOLD* to DAGLJAM
I've owned these for 2 months but need the longer custom cable I have on my Sennheisers. The stock cable is 3m(10ft) long. These do sound better than my Sennheiser and you can get the cable modified from some sources online. They are extremely confortable, hi-res audio ready and can accomodate large heads due to the frame design. Grado and Sennheiser can be snug on some folks.
It's a Top Of The Line(TOTL) AKG headphone with solid construction, unbreakable frame, gold plated connections, replaceable ear cushions and a leather headband. You don't get much better than these IMO.
Revolutionary flat-wire voice coil technology
Patented AKG Varimotion ultra-precision two-layer diaphragm
Self-adjusting cushioned genuine-leather headband
Bi-wiring, high-performance cable with 1/4" jack plug
Comfortable, specially shaped "3D-Form" ear pads
Complete with stylish storage cradle
Individually tested and numbered
AKG 701 Review
Includes: Original box, warranty paperwork and headphone stand.
Cambridge Audio A640C v2.0 CDP - 9/10 - Black - *SOLD* to Bill Ayotte
2006 Award Winning CDP with a bunch of happy Club Polk owners or previous owners. I had it on my computer rig but have only used it 2-3 times since everything I run is actually ON the computer....it was an impulse purchase. The ones listed on Audiogon are v1.0...don't be fooled, that's why they are getting rid of them.
It's the v2.0 which has multiple upgrades over the previous model. Including:
2 x Wolfson WM8740 24-bit/192kHz DACs in dual differential configuration for improved stereo performance
Toroidal transformer for lower noise and less waveform distortion
Upgraded audio filter and regulator stage
Separate power supply
Custom Cambridge Audio servo solution
Extremely low jitter
Coaxial and optical digital outputs
Control Bus input and output for seamless multi-room integration
Low resonance, acoustically damped chassis improves sonic performance
Dimmable LCD
Slim-line navigator style Azur remote control
Stylish all-metal casework with a solid aluminium front panel
Frequency Response: 10Hz to 20KHz +/- 1dB
THD: 0.002%
D/A Conversion: 24-bit/192kHz x 2-dual
Dynamic Range: > 100dB
Channel Separation: > 90dB
Correlated Jitter: < 260ps
Digital Outputs: Optical and Coaxial
Max. Power Consumption: 17 Watts
Dimensions (W x D x H): 430 x 310 x 70mm
16.9 x 12.2 x 2.8"
CA A640C Reviews and Awards
Includes: Original box, packaging, aluminum remote control, power cable & owners manual.
Definitive Technology BP-7006 Loudspeakers - 9/10 - Black - *SOLD*
I'm selling these for a friend and they are in stellar condition. I can't find any flaws or problems. As far as bi-polar loudspeakers go, it's a tremendous HT speaker and the smaller ones seem to image better than the larger models for 2CH. He upgraded simply because he could, so out the door these go. I have all the original packaging for shipping but would prefer a local sale.
Frequency Response: 17 Hz — 30 kHz
Nominal Impedance Compatible with 8 ohms
Rec. Assoc. 20 — 250 Watts
Driver Complement: Two 4-1/2" high definition cast-magnesium basket polymer upper bass/midrange drivers. Two 1" pure aluminum dome tweeters with silk surrounds. One 8" long-throw subwoofer coupled to two 8" infrasonic radiators.
Connections Gold-plated 5-way binding posts and optional LFE input.
Auto on/off.
Efficiency 92 dB
Includes: Original packaging, user manual, spikes and additional wedge feet.
THANKS FOR READING! Contact me directly with any questions!
S5223CXFM
S092107GKA
S036273CDAN
S573C046AC
0566007PBTD
Post edited by dorokusai on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2008
  • unc2701
    unc2701 Posts: 3,587
    edited January 2008
    Is the headphone stand pictured? :D
    Backburner:Krell KAV-300i
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited January 2008
    Damn it, If that C372 is still around in a week......Man, now I'm gonna need to find closet space for the C230BEE....
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited January 2008
    AKG's for me please and a pm...
  • dorokusai
    edited January 2008
    The AKG and MF X-Can are gone folks.....thanks Dave and Danny :)
    I still have some stuff available....talk to me people.
  • dorokusai
    edited January 2008
    unc2701 wrote: »
    LOL No, it's inside the box but that was pretty funny.
  • dorokusai
    edited January 2008
    Bill - I think you should use the BEE in the master bathroom :D
  • DAGLJAM6
    DAGLJAM6 Posts: 635
    edited January 2008
  • dorokusai
    edited January 2008
    I added pics of the Definitive Technology loudspeakers and the **** end of the NAD C372. The socks have been tightened, panels polished and connections of both pieces spruced up with some Pro-Gold.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2008
    dorokusai wrote: »
    Whaddaya' got? :)
  • dorokusai
    edited January 2008
    Hmmmm...I have a couple goodies :)
    A gut shot of the NAD was added prior to packaging and if anyone is interested, a Cambridge Audio A640 Integrated Amplifier(v2.0) is in the wings. The aqua blue circuit boards on the NAD remind me of vintage Nakamichi gear.
  • BlueMDPicker
    edited January 2008
    DAGLJAM6 wrote: »
    I auditioned a pair of those yesterday when some folks dropped by from the Carver forum. They're terrific. Enjoy!
  • Bill Ayotte
    edited January 2008
    dorokusai wrote: »
    That's where it is now, I'm thinking this and another set of speakers I have seen in the FM here....
  • DollarDave
    DollarDave Posts: 2,575
    edited January 2008
    dorokusai wrote: »
    I would like to know more about the Cambridge.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2008
    Doro, this is sheer torture for me in my current predicament. I hope all these nice toys go to good homes.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Chicomoralessxm
    Chicomoralessxm Posts: 417
    edited January 2008
    Doro, do you have any nice bookshelves for sale? Those Deftechs are nice....but the size and shipping will be a killer for sure.
    Chicomorales:)
  • dorokusai
    edited January 2008
    DaveMuell wrote: »
    Dave - I'm remote at the moment but check out www.cambridgeaudio.com for the particulars about the integrated. It's the v2.0 which has some nice upgrades from the previous model.
    Darla - Thanks :) My objective is too create as much audio turmoil in Polkies lives as possible.
    Chicomoralessxm - Nothing extraordinary but I am upgrading my HT to LSi and would have some RTi38, original owner and packaging, that I'd get out the door for a nice price. I can get Usher Audio loudspeakers if you like the S520.
  • DollarDave
    edited January 2008
    Does your Cambidge have the optional phono inputs?
    Silver, or black?
  • Chicomoralessxm
    edited January 2008
    dorokusai wrote: »
    Well i'm looking for something with a little more oomph than those ushers. Was seriously looking at the lsi9, dyna 52's, 140's or the studio 40. But recently my budget took a major hit so i'm on the look out on the used market, demo or closeouts now.
    Chicomorales:)
  • dorokusai
    edited January 2008
    Fair enough, that makes sense. I would suggest LSi7 instead of the LSi9. You would be suprised how nice they sound, as well as the "oomph".
  • dorokusai
    edited January 2008
    The DefTech's are in a new home but I still have a few killer integrated amps and a benchmark CDP available. If you want to talk turkey, drop me a line.
  • MKZ
    MKZ Posts: 1,068
    edited January 2008
    dorokusai wrote: »
    I like to get one if you have it available. Thanks.
  • Chicomoralessxm
    edited January 2008
    dorokusai wrote: »
    Ok if you manage to get your hands on a pair let me know? would they go good with music hall? just wondering how they would compare to the paradigm titan v5 or the older MA S2
    Chicomorales:)
  • BlueMDPicker
    edited January 2008
    If no one here grabs the A640C, let's talk. I've got plenty-o-gear so I'll wait to see what develops.
  • dorokusai
    edited January 2008
    Mike - Ok, will do. I got your email and will get by this week. Thanks for picking that up.
  • dorokusai
    edited January 2008
    Just FYI, the Cambridge Audio 640C's listed on Audiogon are the v1.0....not the v2.0.
  • dorokusai
    edited January 2008
    Thanks Bill, you rule and thanks for getting me closer to my sex change. The woman suit is getting dry and the cocoa butter isn't working anymore.
    What ever happened to haggling? I still have a mid-fi giant killer CDP available.
  • Bill Ayotte
    edited January 2008
    Glad I could get you that much closer to getting rid of that pesky beanbag...;)
  • dorokusai
    edited January 2008
    It's like old man balls from the Jackass movie.
    Seriously, thanks Bill, it's great to do business with the gang. - Regards, Mark
  • dorokusai
    edited January 2008
    CDP anyone? I don't think you'll find a better user group level, flea market on the internet for used/new audio gear. Look at all the stuff in this place?
