RTA 11t
MillerLiteScott
If I were to upgrade the cross overs in my 11t. I already have rdo 194's
I would need the following?
2 12uF mylar
2 12uF electrolytic
2 34uF electrolytic
2 2.0 mills resisters 5w
2 2.7 mills resisters 5w
What is the difference between mylar and electrolytic?
Scott
2 12uF mylar
2 12uF electrolytic
2 34uF electrolytic
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
Omit the 12uf cap that parallels the resistor, and you might as well use 12 watt mills resistors, and you are good:)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
So for the high end I only need 1 12uf Cap and the 2 resisters?
And the low end only needs the 34uf Cap?
Good to go?I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
MillerLiteScott wrote: »So for the high end I only need 1 12uf Cap and the 2 resisters?
Good to go?
Yes sir. I have done this mod, and Jake too. It adds some detail, and saves money:) What kind of caps are you using?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thanks for the info Ben. I will probably maintain the original spec though. I am looking at doing either Sonicaps or I may try the Daytons. I have to consider how much I put into these speakers.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
