12v trigger cable
NeilGabriel
NeilGabriel Posts: 1,487
edited January 2008 in Electronics
I need a 12 v trigger cable that terminates in bare wire (or spades) to connect to the amp that I want to trigger. I can't find any online. Anyone have a link? Thanks much.
Post edited by NeilGabriel on
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2008
    Can you just take a regular cable and make your own, cut the end and either use the bare wires or attach whatever interconnect you'd like?
  • janmike
    janmike Posts: 6,146
    edited January 2008
    Try Radio Shack.
    Michael ;)
    NORTH of 60°
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited January 2008
    I agree with Mike, just buy an 1/8" mono cable, and strip one end to bare wires. Worked fine on my old Rotel.
  • Ethancf
    Ethancf Posts: 459
    edited January 2008
    WilliamM2 wrote: »
    Yep...did that same thing for my Parasound 7100 and 2205 amp...worked great!
    THE SYSTEM
    Polk Audio LSi25 Mains
    Polk LSiF/X Surrounds
    Polk Audio LSiC Center
    Definitive Technology PowerField 1800 Subwoofer
    Parasound Classic 7100 Pre/Pro
    Parasound 2205A Amplifier
    Pioneer Elite BDP-05FD Blu-ray Player
    Monster HTS 2600
    Microsoft XBox 360
    Samsung PN64D550 64" Plasma
  • NeilGabriel
    edited January 2008
    Ethancf wrote: »
    I have the 2205A (parasound)....so the trigger only connects to one point on the amp? next to the ground? thanks a lot....
  • Ethancf
    Ethancf Posts: 459
    edited January 2008
    Yup...just like WilliamM2 posted...once you strip the jacket off of the 1/8" mono cable, you'll see two wires. Twist up each wire and connect on the back of the amp (see lower left hand trigger connections in pic).
    Connect the other end to your pre/pro and make sure the trigger power options are configured in the menu options of your pre/pro.
    THE SYSTEM
    Monster HTS 2600
    Microsoft XBox 360
  • rskarvan
    rskarvan Posts: 2,374
    edited January 2008
    Make certain that you purchase a Cardas silver 12-volt trigger cable. <kidding>
  • NeilGabriel
    edited January 2008
    rskarvan wrote: »
    I needed jumpers for my NAD receiver, and I ordered them from NAD at $1.67 a piece (plus 20 bucks shipping). Cardas had upgrades for $80....a pair though! I think......
    http://www.dedicatedaudio.com/inc/sdetail/5274
