RC55i - Need a center channel solution
Hello,
Can someone suggest a small center channel to match the RC55i's? I am having trouble finding something I can mount on the wall. If not, does anyone know of a speaker mount that can accept large speakers?
Thanks for any info you can provide.
Post edited by GerardB on
Hello,
Would the Polk Audio RM7C work with the RC55i's or is the CSR the smallest solution? Is the RM7C timber matched with any of the in-walls?
Does anyone have any suggestions regarding mounting the center up high and angling the center down to the listing position? Are there any recommended wall mounts?
Thanks -
The CS1 and CS2 are the timbre matched models for those speakers. Bigger is better, so if you have the budget and space the CS2 would be a great center.
I don't have a good suggestion on the wall mounting.
Welcome to Club Polk and stick around, a lot to be gleened from many of the folks here. -
Thanks for the help. Space is very restricted and I need to mount the speaker above the TV. Most of the wall mounts that will hold a speaker that big (like the CSR) are for mounting small TVs or components. I just want to confirm that the CSR or CS1 are the smallest, timbre matched speakers that I can use with the RC55i's. I will keep looking for a wall mount that will support a CS1. Thanks again.
