Belkin Pure AV and Powered speakers
mhartman29
Any thoughts on how to connect my powered speakers (RT3000s, CS1000) with the Belkin PureAV 60? The PureAv has 2 high output connectors for amps and such. One of those is taken up by my power amp, which leaves one left.
Also, I'm dealing with only one outlet that is near my setup. Assuming I need to use another power strip/surge protector, is that OK to plug that into the same outlet that the PureAV is plugged into?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Post edited by mhartman29 on
No one has any thoughts or advice? Does anyone at least know if it is OK to plug a line conditioner and another surge protector into the same outlet? For some reason I seem to recall this isn't adviced, but if that is the case I don't have enough plugs everything I need connected!Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Ultra speaker cables -
I have a UPS and a line conditioner in one outlet, and a sub and another line conditioner into another outlet without any problems."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thank you, Face!Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
