1080p upscaling
Dave38
Dave38 Posts: 101
edited January 2008 in Electronics
If I have a pre-pro that does 1080p upscaling and I have a TV that does the same, how does this work? Does the TV auto detect the 1080p signal and then doesn't have to upscale?
Post edited by Dave38 on
  • PhantomOG
    PhantomOG Posts: 2,409
    edited January 2008
    The TV will take whatever signal you send it and upscale it to display at 1080p.
    If you send it a 1080p signal the TV will recognize this and it doesn't need to do any processing/upscaling.
    The real question is whether or not your pre-pro is better at the upscaling than your TV.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Dave38 wrote: »
    I believe you can set each unit to do the upscaling. I would set the tv to not upscale and see how well the AVR does it. Then set the AVR to pass the raw signal through and let the TV upscale and see how well the tv does it. Pick the best picture.
    Right now your tv is not upscaling if your AVR is. Its doing like you said, reading a 1080p signal and leaving it as is. But your Tv's internal chip might be better than the AVR's, so run the test like I've described.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • PhantomOG
    edited January 2008
    jakelm wrote: »
    I would set the tv to not upscale ...
    With a fixed pixel display I don't believe this is possible. It has to display at its native resolution. The only time it doesn't upscale/process the signal is if you feed it its native resolution.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    PhantomOG wrote: »
    Your right ,what I ment was set the AVR to send 1080p signal, like he has it now. Then set the AVR to pass through raw signal (probably 480i or 480p)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PhantomOG
    edited January 2008
    speaking of which, does anybody know if there are any receivers out there which upscale/output over HDMI with the on screen display viewable over HDMI? Maybe they all do this, I'm not sure.
  • Dave38
    Dave38 Posts: 101
    edited January 2008
    Thanks. I'll try the suggestions posted here.
  • vlam
    vlam Posts: 282
    edited January 2008
    My Denon 3808ci on screen is over HDMI. It's also one of the best I've seen.
    Main Gear
    Panasonic 50" Plasma, Polk LSi15 (Front), LSiC, LSi7 (Rear), Sherwood Newcastle AVP-9080, AM-9080 bi-amp to LSi15, AM-9080 bi-amp to LSiC and LSi7.
