no power to sub so replaced the fuse and the fuse kept on blowing?????
newbie2k8
My psw 140 sub hasn't been working for a while and I haven't had time to look into to it. Well I called polk tech support and they recommended that I take apart the sub and check the fuse. Well I did and to my surprise the fuse was blown. So I thought today was my lucky day and all I had to do is buy a new fuse and replace the bad one and I was going to have my sub back. Well I did just that and as soon as I plugged my sub in the fuse blew. So I did it again and same thing the fuse blew so I tried one more time and again for the 3rd time the fuse blew just after replacing it and plugging it into the wall. I even tried plugging it in to my surge protector and another blown fuse???? Any help with be greatly appreciated as I hope that it's something simple. Thanks
Post edited by newbie2k8 on
Repost under 'trouble shooting', more than likely, you'll have to call Polk c.s., and they'll tell ya the shipping instructions, etc.
I had the same thing happen w/ psw303, but the local Tweeter I bought it at just swapped it out because it was discontinued.
Good luck, and welcome to the forumI refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Thank you for your help I really appreciate it
