All Channels Driven
math wizard
I've searched this forum and have not found a satisfactory answer to this question. How can I tell if the power rating for my AVR is for "all channels driven?" I have a Yamaha RX-V2500 which is rated at 910 watts (130 watts x 7 channels). This is a considered a high current amp. From the users manual, it is not clear if it means all 7 channels or just 2 channels. Can someone here tell the answer or atleast point me in the right direction so that I can find it? All replies are appreciated.
Processor - Emotiva UMC-200
Pre-Amp (2 Ch) - Emotiva USP-1
DSP Minidsp nanoAVR DL
DAC (2 Ch) - Emotiva XDA-2
Amp (Fronts) - Emotiva XPA-2
Amp (Center/Surrounds) - Emotiva XPA-3
CD - Emotiva ERC-1
Fronts - Polk Audio RTi 12
Center - Polk Audio CSi5
Rears - Polk Audio RTiA1
Sub - Epik Knight
Sub EQ - Velodyne SMS-1
Monitor - Sony XBR65X850C
Blu-Ray - OPPO BDP-203
Network Media Player - Chromecast Ultra
Power Conditioner - APC H15
Power Conditioner - Emotiva CMX-2
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Post edited by math wizard on
I seriously doubt an receiver of any maker will put out 930 watts total. But saying that must AVR / receivers have inflated true output rating. Look at the tread "Show me your guts" and look for some amp's which are true rated output, start looking at the transformers, the filter caps needed to put that kind of wattage.
Saying that relax if your receiver have preamp outputs, enjoy it today, learn and or grow from it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Probably something in between. You certainly won't get 130x7 with all channels driven. I found a review for the 2600 which is a 130x7 also. At 6 channels driven at 1KHZ, the output was 119wpc. With 7ch driven, your results will even be less. Here's the link, http://www.soundandvisionmag.com/receivers/1497/test-bench-for-shootout-three-mid-price-av-receivers-page3.html
IMO, those are respectable numbers. -
Thanks. I look at the review and thought that the numbers are respectable also. Not far off from the spec. at 6- channels driven. I could not find the
"Show me your guts" thread.Processor - Emotiva UMC-200
CD - Emotiva ERC-1
Sub - Epik Knight
PVR - DirecTV C61k
Remote - Harmony Touch w/Hub -
Yamaha rates them with two channels driven. Here is a review, it did meet the published specs:
http://www.audioholics.com/reviews/receivers/yamaha-rx-v2500/rx-v2500-benchmark-tests-part-1 -
You know what's interesting about that review is that in 4 ohm setting, the power output at 20hz for 1ch is 199wpc as opposed to 147wpc in 8 ohm setting. This is what I would expect. But when you look at the 2ch ratings for 4 and 8 ohm, the power is less in 4 ohm (119wpc) than 8 ohm (135wpc). This is not what I would expect.
math wizard wrote: »Thanks. I look at the review and thought that the numbers are respectable also. Not far off from the spec. at 6- channels driven. I could not find the
Sorry I gave you the wrong thread name but here's a link of what I was talking about. http://www.polkaudio.com/forums/showthread.php?t=26433
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
my old marantz sr4400 apparentley was capabale of driving all channels continuasley, however one day i decided to try this by splitting a stereo signal into 3 sets of them and then compensating for the loss over each chanel by adding 6db. it did drive them without clipping (to my reconing), but the sound was quite harsh. and the amp soon got verry hot.
one thing i cant understand is why the amp said power consumption was 315watts and the power output was 6x 80wrms @ 8ohm and 6x 95wrms @ 6ohm (min), that means that the out is bigger than the in , that is impossible.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
wallstreet wrote: »You know what's interesting about that review is that in 4 ohm setting, the power output at 20hz for 1ch is 199wpc as opposed to 147wpc in 8 ohm setting. This is what I would expect. But when you look at the 2ch ratings for 4 and 8 ohm, the power is less in 4 ohm (119wpc) than 8 ohm (135wpc). This is not what I would expect.
Know that impedence switch in the back? That's why you leave it in the 8 ohm position.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
My HK has this. Which I take as all channels driven.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
The FTC had (still has, AFAIK) a very stringent way to report power for two channel amplifiers for home use. Car audio and multichannel formats always were and still are exempt from the letter of the law. As a consequence, there is no standard, and manufacturers can (and do) report whatever they see fit. The better manufacturers at least tell you what their standard is.
I'd doubt it. My Onkyo TX-SR702 is rated at 7*100W, yet IIRC in Sound and Vision they tested all channels driven and found it to be only 52WPC.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
