Really dumb question
Serendipity
Serendipity Posts: 6,975
edited January 2008 in DIY, Mods & Tweaks
When replacing electrolytic capacitors in audio/video gear, is it okay to use capacitors of a higher voltage capacity (but same uF value)?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • madmax
    madmax Posts: 12,434
    edited January 2008
    Yes.
    madmax
    Vinyl, the final frontier...
  • rskarvan
    rskarvan Posts: 2,374
    edited January 2008
    I think the printed voltage capacity is more/less a maximum value. So, going higher means that the capacitor is rated for "up to" this voltage rating. However, the tolerance of the capacitor value may change.
    "There is a voltage dependency that is in addition to both the initial tolerance and the temperature coefficient. For some types, operating at full rated voltage reduces the capacitance to less than half of the zero voltage capacitance."
    In transient circuits, everything affects everything. The question really becomes, "will the difference be significant". The answer is probably... "I hope so... but, in a good way". Whether or not that is the case depends on your ears.
    http://wiki.xtronics.com/index.php/Capacitor_codes
  • Serendipity
    edited January 2008
    Thanks.
    So I will have no problem replacing the capacitors in my VCR?
  • Systems
    Systems Posts: 14,872
    edited January 2008
    appadv wrote: »
    Thanks.
    So I will have no problem replacing the capacitors in my VCR and projector this way?
    It will not harm the equipment, right?
    Higher voltage is fine and be sure to install them with the correct polarity or you will have a mini bomb when voltage is applied.
    Testing
    Testing
    Testing
    treitz3 Posts: 20,088
    edited January 2008
    appadv wrote: »
    No, it will not.
  • Serendipity
    edited January 2008
    GV#27 wrote: »
    Thanks, I already replaced the video head (drum) in my VCR and it went fairly easily.
    Now, this has me puzzled - how do I replace surface mount components? I found some shorted capacitors (on a few pieces of dead equipment) that are of the surface mount type.
    edited January 2008
    Hehe. You don't. One exception and you have to have one HELL of a steady hand, fine tipped soldering iron and experience with surface mounted components. Other than that, replace the board.
    Surface mounted boards are pre-tinned, components are put into place, then they are oven baked....not to be repaired, just replaced. FYI.
  • Serendipity
    edited January 2008
    treitz3 wrote: »
    Nice, however the board that I am trying to replace (with the failed capacitors on it) costs over $1500 from the manufacturer. I already checked and it was VERY expensive.
    On a positive note, I've had good success with VCR repairs :)
  • Serendipity
    edited January 2008
    So is there any way that I can repair it myself?
  • Systems
    edited January 2008
    appadv wrote: »
    Maybe:)as Treitz3 suggested you will need a fine tip iron, also a magnifying glass will be of help.SMD electrolytic caps have a solder tab on each side at the bottom of its case. You can use solder wick or solder sucker and carefully desolder the old part.Dont apply too much heat so as to not lift or damage the traces.If you succeed then solder in the replacement.
    Testing
    Testing
    Testing
  • Serendipity
    edited January 2008
    Thanks for all your help guys!
    I'm not sure if I can do the surface mount stuff yet as the board I am working with is multiple-layered.
  • Serendipity
    edited January 2008
    GV#27 wrote: »
    When you say mini bomb, how bad is that?
    I know capacitors are marked on their negative terminal, so I'll be sure to install them the same way the original capacitors were done.
    edited January 2008
    appadv wrote: »
    Depending on the current, voltage and capacitance, small firecracker to deadly. This is an area you don't want to make a mistake with.
  • Serendipity
    edited January 2008
    treitz3 wrote: »
    Wow, I'll be sure to install them correctly.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2008
    I didn't think that was such a dumb question.
  • Serendipity
    edited January 2008
    Haha, I don't know much about electronics repair :)
  • Systems
    edited January 2008
    Can I donate a VCR to keep things safer?
    Testing
    Testing
    Testing
  • Systems
    edited January 2008
    appadv wrote: »
    I work as a QC tech for an electronics manufacturer and have had a few smaller ones blow on my bench and I can assure you that without my safety glasses I would have had eye damage.My glasses were covered in electrolyte fluid and part of the metal casing hit them as well.:eek: Ofcourse I should have caught the error on the visual inspection before powering up:o
    Testing
    Testing
    Testing
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2008
    This question sounds way too smart to be dumb . . .
  • madmax
    edited January 2008
    The best way to remove SMT components like capacitors and resistors is with two irons if you have them. However, since the parts are bad anyway don't worry too much, just go back and forth quickly on the two connections until it comes loose. You are trying to get it hot enough on one side to stay melted until you get to the other side.
  • Serendipity
    edited January 2008
    madmax wrote: »
    Thanks, seems difficult though...
  • Serendipity
    edited January 2008
    All in all, I am happy that replacing the caps made a difference.
