Which terminals are which???
brtt485
Are the top terminals on my Monitor 70's for the highs/tweeters, and the bottom for my mids/woofers???
If yes as I believe, is this a universal truth and the way ALL speakers are designed?
Thanks for your help
Post edited by brtt485 on
yes that's correct.... if you remove the metal jumpers then they work separately.. with the jumpers in place they were in tandem.PolkFest 2012, who's going>?
This is universal. I have never seen it anyother way, but I would expect it to be labeled if it was.
