iTunes and What Else?
jakelm
jakelm Posts: 4,081
edited December 2007 in The Clubhouse
My son just got a iPod Nano, for Christmas.
Him and I have tons of music already on the Pc in MP3 format. What else becides iTunes can we use to transfer our music to the iPod? I use WINAmp to listen to all my music. Can WINAmp be used or do I have to use iTunes?
This iPod is not as easy to use as the "drag and drop" MP3 player we have. So this is all new to me.
Do all the songs have to be converted to Quicktime? Or some type of Apple .****?
There is alot of info on the iPod subject , but not much on this one.
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
  • hoosier21
    hoosier21 Posts: 4,418
    I don't know as I don't have an Ipod.
    Did that Nano come with a manual? Try looking there. :)
    But I think your stuck with Itunes.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • jakelm
    jakelm Posts: 4,081
    Manual says iTunes. Which is expected since its all Apple.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • BaggedLancer
    BaggedLancer Posts: 6,371
    itunes is easiest when dealing with the ipod.
  • DufferDan
    DufferDan Posts: 10
    I'm not a fan of iTunes, so I use MediaMonkey; http://www.mediamonkey.com/
    The free version works well for me.
    Fairways and Greens,
    DufferDan
  • bobman1235
    bobman1235 Posts: 10,822
    iTunes deals in MP3s just fine, so if you're just trying to switch because you don't think you'll be able to use all your old MP3s, give iTunes a try.
    If you just don't like iTunes, yes, you can use WinAmp to sync with your iPod. A Google Search turns up a few helpful links :
    here, and here in particular.
  • BottomFeeder
    BottomFeeder Posts: 1,684
    I've found iTunes to be incredibly easy - just drag & drop as well.
    Good luck.
    Oh yeah, you can go Apple's web site and find tutorials there.
    "Wish I didn't know now what I didn't know then." Bob Seger
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    use itunes ull love it it orginizes your music and all click file and click Add Folder
    and search for the file that contains ALL your music. your done.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • jakelm
    jakelm Posts: 4,081
    Well since I am already pretty familiar with WINAmp I thought it would be just as easy to use with the ipod. But I will give iTunes a go.. Thanks for the help
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Sherardp
    Sherardp Posts: 8,038
    Drag and drop songs into the library in Itunes, then send them to the Ipod by drag and drop as well. Very simple.
  • jakelm
    jakelm Posts: 4,081
    Ok ,,,getting used to iTunes.
    One more quick question. I bought a few songs. All are 128 bitrate. Is there a way, when purchsing songs, I can get them at a higher bit rate? Also, they are all m4p file. How do I change it to mp3 so I can play it in WINAmp or another application. M4p doesnt seem to play in Winamp.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • nms
    nms Posts: 671
    Any songs you DL with iTunes are in a protected format that limits the number of times the songs can be copied / put on different devices. And no, I do not think you can get tham at any higher bitrate - most people who use itunes don't know or care.
    When I first got my ipod I hated itunes, and still do - it was completely incompatible with how my music collection was organized (Ripped CDs in folders organized by CD, w/ playlists for individual disks). It took me a long time to develop a system to get the music organized in itunes the way I wanted it. What was fun was importing mp3s without metadata, so itunes' method of sorting by artist or album scrambled all my files together. I think it's a terrible piece of software that is poorly written and prone to freezing and hang-ups.
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • jakelm
    jakelm Posts: 4,081
    nms wrote: »
    Well I can say this, in regaurds to song listing. iTunes SUCKS AT IT!! In WINAmp, if the song is filed like.
    Example: Nickelback - Rockstar
    Then WinAmp can tell that Nickelback is artist and Rockstar is song. And will list it (group it) under Nickelback.
    With iTunes, if the Artist part of the file is not filled in, then iTunes will ship it to the bottum, instead of listing it as it should. Very aggrivating.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • nms
    nms Posts: 671
    That was precisely my problem. When I first started ripping CDs I used software that didn't fill in the artist, album, genre, etc. I eventually resorted to clearing all the check boxes in itunes, importing another folder of music, then hunting through all the music listed until I found the ones with checks - very time consuming and error prone.
    My system
  • bobman1235
    SO because you guys didn't rip your music in a way that is the industry standard, it's iTunes fault for using the standard? Thank God none of you work in software.
    iTunes has a lot of faults, but the way they organize the music isn't one of them. You can't expect a music player to guess what the artist and song title are based on some arbitrary name you gave the mp3 file when there is a real way to set that information within the file.
  • jakelm
    jakelm Posts: 4,081
    No Bob, not blaming iTunes. WinAmp and WMP and other programs seem to have no problem reading and listing my music, just iTunes. Sometimes, following industry standards and ONLY that standard can be a bad thing.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    And Bob, you have to admit, iTunes software could be alittle more flexible.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • bobman1235
    Oh, dude, believe me, I think iTunes has a LOT of faults, I just don't see that as one. Having used WinAmp in the past, I don't think that does exactly what you think it does either, but I could be wrong.
  • nms
    nms Posts: 671
    No, it's my fault for ripping the music without the metadata (but I never needed it before to organize my music), but it IS itunes' fault for not failing gracefully when the metadata was not present. There is no option to group music by folder, for instance. It all gets dumped into one pile and then you have to create playlists out of the big jumble. I have to agree that itunes is EXTREMELY inflexible in how it allows you to organize and handle your music.
    My system
  • TroyD
    TroyD Posts: 13,124
    iTunes blows.
    BDT
  • bigaudiofanatic
    there is no way that there is any other better music sorting library out there PERIOD. Use is and enjoy how easy it is to find the songs you want if you want to up the bit rat go to Edit - Preferences - Clicke Advanced Tab - Click Importing Tab. and change it to what bit rate you want I use Apple Lossless it's AWSOME. Enjoy it better than any player out there o and for the people that use another prgram for the ipod IT VOIDS YOUR WARRANTY AND my freind used another program for about a mounth than it crashed his ipod.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • nms
    nms Posts: 671
    there is no way that....... [deleted for brevity]
    What are you, an apple employee or something?
    My system
  • jakelm
    jakelm Posts: 4,081
    there is no way that there is any other better music sorting library out there PERIOD. Use is and enjoy how easy it is to find the songs you want if you want to up the bit rat go to Edit - Preferences - Clicke Advanced Tab - Click Importing Tab. and change it to what bit rate you want .
    Does this work when buying songs? I tryed, my songs are still 128bit.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • bobman1235
    Nope, w hen buying songs you're stuck with what they give them to you in. I vaguely remember hearing of someone offering higher bitrate songs, don't remember who or when.
  • jakelm
    jakelm Posts: 4,081
    bobman1235 wrote: »
    Gotcha....Thanks Bob.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PolkThug
    PolkThug Posts: 7,532
    iTunes and iPods suck, proprietary FTL.
  • cmy330go
    cmy330go Posts: 2,341
    I have my gripes about iTunes, but must say that it is the best way to organize large amounts of music. I've tried Real, WinAmp, Media Player, etc... and have yet to find a program I prefer overall.
    I would do a little more research about available bit-rates. I remember reading not long ago that iTunes was going to start offering higher bit-rate options.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • cmy330go
    OK. I found some info on their website you might want to check out. Hope this helps you some.
    http://docs.info.apple.com/article.html?artnum=305567
    HT
    2 CH
  • bigaudiofanatic
    Nope not an employe just a guy that knows what works and what SUCKS
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
