7.1 Setup...Please Help
gamnchinoca
I am planning to get a new receiver...pioneer vsx-94tx. I need your help in setting a 7.1 system. The room is 13 by 15 which is connect to open kitchen which is another 13 by 30. Please help as to whick Polk speakers I should use. My budget is 2K - 3K excluding the receiver. Thanks
Post edited by gamnchinoca on
Did you have specific questions? "please help" is a little open ended...Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
Rti10s, CSi5, Fxi3s, Rti4 or substitute the Rti10s for 12s and of course SVS or Epik Subwoofer.Shoot the jumper.....................BALLIN.............!!!!!
Ok, since I am plannning to get Sony 52XBR4 or 5 I think am want to get the Klipsch Icon series or the Polk VM series. 7.2.....2 VM30, 1 VM20, 4 VM10, and 2 DSW Pro 600. What do you think?
