Help w/ PSW650
MAP1911
MAP1911 Posts: 34
edited March 2003 in Troubleshooting
I have a Polk PSW650 in my TH. It just stopped working. The green light goes on but I get NO bass out of the sub.
I used it on Monday with no problems.
Any suggestions or help would be appreciated,
TIA
Mike
Post edited by MAP1911 on
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited February 2003
    Check for a blown fuse - probably around 3 or 4 amps.
    Check your AVR for a spontaneous settings change (i.e., sub is now set to no/off).
    Check for a loose or disconnected sub cable.
    SVS
  • MAP1911
    MAP1911 Posts: 34
    Dr. Spec,
    Thanks for the quick reply. I checked 2 & 3 and they are OK.
    I looked in the Instructional Manual that came with the sub and there is no mention of a fuse. Can you provide more info?
    Thanks again,
    Mike
  • Dr. Spec
    First try a speaker level connection to the sub from the mains output. Set the mains to large and the sub to off/no and connect one of the mains leads to the sub and see what happens.
    Re: the fuse - some plate amps have a fuse - I don't know about the 650 in particular.
    SVS
  • MAP1911
    MAP1911 Posts: 34
    edited March 2003
    I spoke w/ Polk customer service today (3/3/03). They talked me through trouble shooting the problem. It came out that one (1) of the drivers was not working. So, off to CA for a replacement.
    Dr. Spec, thank you for your assistance.
    Mike
