Pics of Bucks SDA 1.2TL's
buckfishing
buckfishing Posts: 11
edited December 2007 in Vintage Speakers
I've never been on a sight like this so I'm not familiar with many of the ways to re-post, reply, and so on. I'll do my best. I have taken some pics so you guys came positively ID my speakers. From there I'm sure I can start getting down to business. I appreciate all your patience and help!!
Buck
P.S. Although John Candy was a great actor and comedian, fortunaltly there is no resemblance.
Post edited by buckfishing on
  • hoosier21
    hoosier21 Posts: 4,415
    a close up of the tweeters would help, they look like the SL3000's, if so, you may have the 1.2tl's, which are the latest model.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Joe08867
    Joe08867 Posts: 3,919
    They definately look like SL3000's. I would have to say 1.2tl's.
  • shadowofnight
    shadowofnight Posts: 2,735
    And from the small pics they look to be in AWESOME shape for a 100 bones :D
    The first rule of Fight Club is you don't talk about Fight Club
  • John in MA
    John in MA Posts: 1,010
    My 1.2TLs are in the 6470 range and were bought in late 1989.
  • whitetruk
    whitetruk Posts: 311
    pretty sure mine say tl after the 1.2,
    I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
  • whitetruk
    in the serial #
  • whitetruk
    sorry just checked mine the right channel does not say tl but
    the left speaker says 1.2tl in the serial #
  • hearingimpared
    hearingimpared Posts: 21,136
    Mine say TL on both speakers in the serial number. I've posted a picture of my SL 3000 when I sold them. You will see what I mean by brassy dome.
  • John in MA
    Mine don't say TL on them anywhere, either.
  • hearingimpared
    Hey Mister Computer Hater where are you?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    Serial numbers on mine are 6387 and 6400. Does not say TL.
    SDA SRS 2.3TL's
    SDA 2B TL's
    F1nut Posts: 51,688
    Listening to pure musical bliss. :D
    Anyway, Polk routinely used leftover labels, etc. and it's a known fact that not all SDA SRS 1.2TL's have the TL on the S/N label. One way to ID them is to check the number on the crossover, the TL is BE2000-C and the 1.2 is BE2000-B. Another way is to look at the crossover plate, the 1.2 TL has one bolt in the middle while the 1.2 has 5.
    Adding to the confusion, Polk offered an upgrade kit for the 1.2 converting it to a TL, but I do not beleive a new crossover plate was part of the package.
  • John in MA
    Didn't some of the later 1.2s use a one-bolt plate?
    My 1.2TLs are 6466 and 6472, and no TL markings.
