Vintage Tube Juke Box Thingy in basement...
MrNightly
Ok, so I have this Vintage Tube style jukebox in my parents basement, and I was messing around with it the other night... took some pictures, and didn't know if anybody knew if it was a true pieces of equipment, or a piece of junk?
It still works, but has never been taken care of. The tubes still warm up and it hums, but haven't been able to get a true signal. I haven't hooked up an antenna yet either, details details.
Anyways, anybody have any experience with this? It says it's a Zenith... Pretty cool regardless. Might be a good project to get back up and running full strength with new wiring and everything... except I don't know anything about that kinda stuff! Ha.
Pictures below...
Pictures below...
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Post edited by MrNightly on
[IMG][/img]
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
There are some old school console gems but I'm not about to school you if it is
It's very cool.
Either way, there are a bunch of collectors for these models....check out AK.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
kewl !!
That is bad a$$Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
It's very cool.
Ya, I know nothing about this kind of item... please school away!
And AK means what again? Thanks!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Not much to it is there!
www.audiokarma.org
Great website for old school folks.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Not a jukebox, it's an older style floor radio. The electomagnet on the speaker shows it's fairly aged. That one looks to be in excellent condition. I no longer keep up with the values of these things but chances are it's worth good money. Do not plug it in or try to play it until all the capactitors have been replaced. As it is, you could blow a transformer and ruin the radio if you do.
Great advice!John in MA wrote: »Not a jukebox, it's an older style floor radio. The electomagnet on the speaker shows it's fairly aged. That one looks to be in excellent condition. I no longer keep up with the values of these things but chances are it's worth good money. Do not plug it in or try to play it until all the capactitors have been replaced. As it is, you could blow a transformer and ruin the radio if you do.
My father collects antique radios. He gave me one to put on display in my living room and told me to NEVER plug it in for the aforementioned reason."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Great... I just plugged it in last week... and tried to tune in a station... hope i didn't ruin it!!! How do i change the capacitors? I need a manual!!!
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Changing caps is usually pretty easy if you can solder.Great... I just plugged it in last week... and tried to tune in a station... hope i didn't ruin it!!! How do i change the capacitors? I need a manual!!!
The difficult part may be identifying them.
Ya, I dunno about all that... I might have to really learn what I'm doing to start soldering things that old!!!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
I haven't soldered anything in years so I bought a pair of Polk Monitor 7C crossovers off of ebay to practice with."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
That would be awesome just as a show piece in an audio room or any room for that matter...very niceThe first rule of Fight Club is you don't talk about Fight Club
Old stuff is easier to solder than new stuff. Nice big connections. Read a few vintage radio restoration websites to get the info you need, and be careful. You don't want to screw it up, or get hurt.
Other than capacitors and the odd resistor, nothing in a tube radio has a finite lifespan. They'll go forever as long as they're maintained. -
I had a 1960's Telefunken console in my carport for over a year, ran like a top. I never even thought about replacing capacitors or other BS.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Did the hobo take it with him when he moved?
Older tube equipment's capacitors will be totally dried out by this point. It's fairly common to see caps in these radios either melt or explode when powered up. It's happened to me a few times in the past. If you're unlucky some irreplacable part of the radio will be damaged when they go. -
I have a older blaupunk in the basement. I am going to take it out and take pictures of it.
CRj -
George Grand wrote: »Did the hobo take it with him when he moved?
No, when he stopped warbling, I had to put him on "ice".CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
John in MA wrote: »Older tube equipment's capacitors will be totally dried out by this point. It's fairly common to see caps in these radios either melt or explode when powered up. It's happened to me a few times in the past. If you're unlucky some irreplacable part of the radio will be damaged when they go.
And yet it sounded wonderful, made it through a winter in Maryland and rocked for 2 summers before I cannibalized it for parts.
I'm aware of those facts John, it just didn't happen to me.....this time. Other gear, well that's different.
So... any idea's how much it might be worth?
In current condition, and also if it was refurbished completely?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Free - $50.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I'll try to find out for you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
See here for more information:
http://www.enginova.com/Zenith_10S464.htm
http://www.radiomuseum.org/r/zenith_10s464_10_s_464_ch1005.html
These are beautiful rare sets. Not always worth a ton before restoration, but the collectors love them. -
Wavemagnet antenna, tone buttons, that thing is pimp!
Wow. AM and shortwave. Kinda different."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson
Those things are awesome!
John in MA wrote: »See here for more information:
Thanks man! That one guy did some impressive work on his... with the detail he put into it, I might be able to follow that game plan.
Very cool... My first thought was to see how much it could bring, but after reading a little more on it, it would be a pretty cool "toy" to have around, if it was truly operational and fixed up.
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
