subwoofer decision help
acsubie
in the market for a new sub to clean up the bass a little in my HT setup, not like the polk psw10 is bad, just want to know i have good equipment, my room is on the smaller side, so i dont wanna over bass it, even though i can just adjust to my liking....right now im looking at the elemental designs line of subs and the SVS line( i like that SVS has the cylinder subs, but the way they have them pictured i cant get a real scope of how big they really are, saw a pic of their higher end cylinder next to an object and it was huge to say the least) cylinder might suit me best just because the GF nags about bigger components and it might be better for the way my room is setup
i hear decent things about the ED but to be honest they are quite ugly, my budget is about $700 and the SVS PB 12/NSD2 is a nicer looking subwoofer also, in cylinders the PCi line is in my price range but im wondering if there smallest unit would satisfy me?
anyone with experience with these 2 models, your feedback is appreciated!!
Post edited by acsubie on
eD makes a great sub, you can't beat them for the price! But I agree, they aren't the nicest looking. I believe you can order them bare and then finish the sub yourself."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
SVS has the measurements listed right there on the webpage for each subwoofer. Take a tape measure and it's fairly easy to get an idea of how large each one is. If that doesn't give you a clear enough picture, then grab some poster board and model it. When I was looking at plasmas, besides looking at the different sizes in the store, I also taped an outline on my wall at home and it was very telling! -
And yes, the eD subs sound great, but man are they ugly. I would think that most wives/girlfriends would not be very accepting of an eD sub in the living room unless you did some major refinishing on it
SVS is having a great sale...FWIWCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
You could just throw a sheet over it.And yes, the eD subs sound great, but man are they ugly. I would think that most wives/girlfriends would not be very accepting of an eD sub in the living room unless you did some major refinishing on it
Mine is hardly noticeable with all my other equipment though. "He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
When the bass hits, does it blow up like a tent
Since it only has a port on one side, it pitches a tent would be more appropriate.When the bass hits, does it blow up like a tent
Is your system used more for music or movies. I recently purchased a Martin Logan Dynamo subwoofer from Tweeter when they closed their west coast stores. It has served me very well for music listening. It is within your stated price range. Good luck.[
It's in my HT system, I don't like using subs for music. But due to space constraints, if I needed to use a sub with small speakers, I'd still consider eD(elemental designs). The A5-300 I own is anything but a "one note" sub."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
go for the NSD/2 and be done, or spend a little extra and opt for the PB12+/2 both are awesome subs.Shoot the jumper.....................BALLIN.............!!!!!
I'll throw in my usual recommendation for HSU subs. I have heard the PB12/ISD (have not heard any of the newer models of SVS, nor have I heard any of the ED subs) and I would not say that it had any advantage over my HSU STF-3 for home theater performance.
Having said that, I don't think HSU makes particularly pretty looking or small footprint subs. If you are looking to go for a smaller footprint sub, the SVS cyclinders may be your best bet.My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
the SVS cylinder subs are not small. i owned the mid sized one.. and it was tall.. and big and round... tough to integrate into a room, lookswise anyway. sound was amazing of course.
the cylinder subs are very lightweight though.. which was nice.. I could move it without getting a hernia
PolkFest 2012, who's going>?
I have a pair of SVS-20-39 passive subs that I drive with my Sunfire. They are both huge and acoustically couple so there is never a risk of "over subbing it" unless you intentionally do so. Everyone always looks at them and goes "are those the subs?"
You will not hide these in a room, but they are great looking cylinders and give the absolute best sound of anything I have ever heard anywhere. The room shakes when it should (Transformers/Saving Private Ryan, etc.) but does not overpower in normal scenes. Just remember to adjust your center to medium or small after you install them. I would also encourage you to email SVS for an immediate response on recommendations.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
