Carver PM 1201
zingo
zingo Posts: 11,258
edited February 2010 in Electronics
A Carver PM 1201 presented itself yesterday. I know that he makes pretty soild products, but I was wondering ya'lls opinion of this amplifier? I couldn't really find any information on it, so any thing would be helpful. Thanks
Post edited by zingo on
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited November 2007
  • zingo
    zingo Posts: 11,258
    So this would probably be a no go for the hifi, correct? It's got tons of power, but I have heard that pro amps aren't great for the home.
  • Ron Temple
    Ron Temple Posts: 3,212
    Mylinda from Classic Carver Repair was talking up the PMs to me last year. In effect, more power, similar design and sound quality, but fans. I think we were discussing the PM1.5, but I would think it would hold with the 1201. Plenty of power anyway.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • WilliamM2
    zingo wrote: »
    Don't know, I have never heard that Carver before, and I haven't been impressed by any of the Carvers I have heard.
    The fans would really be an issue with me, but I imagine you could replace them with quiet fans quite easily.
  • zingo
    zingo Posts: 11,258
    Well, I'll give it a try and see how the sound quality is. The 600wpc should be a healthy dose for my SDA 2A...
  • zingo
    zingo Posts: 11,258
    edited December 2007
    Well I demoed the amp today and it sounds amazing. It is sweet how a lot of power can really wake-up some speakers. The sound was cranked up and was barely scratching the LED meters.
    WilliamM2 wrote: »
    The only issue is the fans. They are not loud, but just too audible. Does anyone know of a fix? Replace them with quieter units? Is it possible to disconnect them all together?
  • sluffsmith
    sluffsmith Posts: 1
    Did you ever get a solution to the fan issue on your PM1201?
    I just bought a PM1201, one fan does not work and the other makes a ton of noise. So the both need to be replaced.
    My current solution of turning things up to drown out the sound is not going over well with the wife.
    stew
