Monoprice component cables OK?
mhartman29
mhartman29 Posts: 257
Sorry if this has been done to death, but I'm curious about monoprice's component video cables. I don't have the highest end receiver right now, in fact, it doesn't even have HDMI connectors, so I'm merely looking to use component video to link my receiver to my new plasma.
So, I was looking at the PREMIUM 3-RCA Component Video Coaxial RG-6 18AWG 75Ohm CL2 Rated Cable. I can upgrade to Signals or some of the other popular/more expensive cables when I get a better receiver. But, for the time being, are these OK?
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited November 2007
    The Monoprice cables are fine. No need to get the premium ones though, the standard ones will work fine. I have both, and I found the premium cables way too stiff, and they put quite a strain on the connectors.
  • dorokusai
    dorokusai Posts: 25,576
    I haven't read any bad things about them, go for it.
  • Face
    Face Posts: 14,340
    Their audio cables are better than some popular store brand cables IMO. For your application, I say go for it. For when you upgrade, their HDMI cables are pretty good too, no complaints.
  • 66chevyIISS
    66chevyIISS Posts: 857
    I ran there 35' component cable or my projector. No complaints here.
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • engtaz
    engtaz Posts: 7,669
    I use them and have no complaint. Well made. Connectors fit real tight.
    engtaz
    engtaz
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited December 2007
    I bought 2 Digital Optical, a Subwoofer cable and an HDMI from Monoprice.
    All work just great.
    Don't ever waste your $ with Monster cables.
  • dorokusai
    Mr. Mojo wrote: »
    Absolutely.
