Question for Ron-p and any subwoofer builders
burdette
burdette Posts: 1,194
Where did you get the ports you used in your sonosub?
You say they're each 17".. is that the length specified by software, or was that a default length? (I ask because the longest commercial, flared ports I can find happen to be 17" and I thought maybe you bought the same ones).
I need two 3" ports that are about 21" long, and I'd like to have flared ends... but I can't find complete ports that long and I can't find 3" flared ends to use with PVC pipe.
Thanks to anyone with some information.
