Onkyo TX-SR603X & RT5000
mhartman29
mhartman29 Posts: 257
edited November 2007 in Electronics
Hi all, I'm new to the forum, although I've owned my RT5000 system for about 6 years now. Anyway, I recently picked up an Onkyo TX-SR603X and even though I'm putting the cart before the horse, I was curious if you all thought it would be good enough to power my speakers properly.
Any feedback appreciated!
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Post edited by mhartman29 on
    tonyb Posts: 33,065
    Sure,it will power them,but you'll get more out of them with some more horsepower.
    Had the same set at one time,driven by a sony AVR,added a cinepro amp and they came alive.Relax and enjoy,not a must have for now,but keep it in mind.
  • Joe08867
    Joe08867 Posts: 3,919
    It will work but watch out for clipping.
    You can surely fry your tweeters with clipping.
  • mhartman29
    Thanks for the responses. Any suggestions on an amp that isn't so pricey? :)
    And what is clipping?
    Emotiva LMC pre/pro
    Emotiva LPA amp
    Fronts LSI15
    Center LSIC
    Rears LSI7s
    Dual MFW-15s
    Oppo 980H
  • Joe08867
    From Wikipedia:
    Overview of clipping
    When an amplifier is pushed to create a signal with more power than it can support, it will amplify the signal only up to its maximum capacity, at which point the signal will be amplified no further. As the signal simply "cuts" or "clips" at the maximum capacity of the amplifier, the signal is said to be "clipping." The extra signal which is beyond the capability of the amplifier is simply cut off, resulting in a distorted waveform.
    Effects of clipping
    In power amplifiers, the signal from an amplifier operating in clipping has two characteristics that could damage a connected loudspeaker:
    Because the clipped waveform has more area underneath it than the smaller unclipped waveform, the amplifier produces more power. This extra power can cause damage to any part of the loudspeaker, including the woofer, tweeter, or crossover, via overheating or overexcursion.
    In the frequency domain, clipping produces strong harmonics in the high-frequency range. Extra high-frequency weighting of a signal is more likely to damage a tweeter than a signal that was not clipped. However most loudspeakers are designed to handle signals with abundant high frequencies, like cymbal crashes, which have a greater high-pitch frequency weighting than amplifier clipping could produce. Therefore damage attributable to this characteristic is rare.
    Other effects of clipping include:
    When applied to a musical signal, the clipping may prevent a note from decaying in a normal amount of time. This can cause rapidly played notes to blend together.
    Music which is clipped experiences amplitude compression, whereby all notes begin to sound equally loud as loud notes are be clipped to the same output level as softer notes.
