Help - what goes where!
Samantha31
Samantha31 Posts: 30
Hi
I am in urgent need of a little feedback which might help me get this *new* system hooked up! I just picked all of this up on Saturday and although I have the TV and DVD working, I have no clue as to where to begin with the rest of this system.
Here is what I have...
46" Sharp Aquos LCD
Toshiba HD-A30 HD-DVD
Polk RM6750 Audio System
Yamaha HTR-6030 Receiver
Satellite Receiver
The problem I'm having is that the Yamaha manual tells me to connect a subwoofer cable from the receiver to the subwoofer. The receiver has one jack for this connection, and the subwoofer has to inputs. When I review the 4 page Polk manual it doesn't even mention the subwoofer jack on the receiver???
Are these 2 pieces compatible or was I duped at the store?
My current configuration is pretty basic since I don't have the receiver or speakers set up. I have my satellite feed coming in and going through the monster power bar and connected to my satellite receiver and then to the TV all using the basic coaxial cable. My HD-DVD is hooked up to the TV using my only HDMI Cable.
I have plenty of speaker wire, as well a single, double, and triple RCA jack type connectors. Perhaps I need other connectors/splitters?
Any help would be appreciated!
Sammi
Sharp Aquos 1080P 46D64U LCD :D
Yamaha HTR 6030 AVR
Toshiba HD-DVD A30
Sharp - Blu-Ray
Polk RM6750 5.1 HTS
HD-PVR Satellite Receiver
Post edited by Samantha31 on
  • beardog03
    beardog03 Posts: 5,550
    edited November 2007
    you should be able to go out of the receiver to any of the two inputs on the back of the sub
    Just make sure the power is turned off on the receiver when plugging in Interconnects and cables, as not to damage the speaker(s)
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Samantha31
    Thanks for the quick reply...
    The sub inputs are listed as line-in left and right. Which made me wonder if I should have a splitter???
    Also what jacks should I use between the HD-DVD and Receiver? I can't figure out why the receiver manual wants me to connect video from the DVD to the receiver???
    :-P
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • Serendipity
    Serendipity Posts: 6,975
    Samantha31 wrote: »
    :-P
    You can use a splitter for the line-in jacks, which basically takes the receiver's LFE out and connects it to the left and right Line-in terminals on the sub.
    Also, you can connect the HD-DVD through the receiver, but for best picture quality I would recommend using a HDMI cable to connect it directly to the TV. I used to connect my DVD through the receiver but going directly to my projector/TV gave better picture quality.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Samantha31
    Thanks for the tips guys....
    I have surround sound!
    I decided to hook the sub cable directly from the yamaha receiver sub-out jack to the subwoofer's right side line-in. Then from thee I just hooked the center, front, and surround speaks up directly from the receiver. Then turned the low pass filter fully clockwise, and setting all the speakers to small, crossover to 120Hz
    The DVD is connected directly to the TV using HDMI cable, while the DVD is connected to receiver, using the DVD's analog audio line-out connected to the receivers DVD analog line-in.
    Anyone know if this set up is optimal? Or should I invest in different cable types to improve sound?
    Thanks again!
    Sammi
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • beardog03
    Try setting the sub x-over to 80hz...you may like it better as the sub will dig deeper
    I use a toslink optical cable from the dvd to the receiver...YMMV
    and like it was stated before, you will get a better picture the way you have it...dvd straight to the tv
    Enjoy !
    Oh !
    And Welcome to Club Polk !
    We have a couple of Beatiful Ladies here at CP....it`s nice to have another one !
    Stick around and have some fun !
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Download, print and read a copy of the Home Theater Handbook.
    Also, check out the Education Section of the website, for lots of useful information.
    Welcome to the boards, and thanks for choosing Polk Audio!
    Cheers,
    Russ
  • cfrizz
    cfrizz Posts: 13,415
    Welcome Sammi. Sounds like you have it all hooked up right. Just adjust your sub crossover as suggested, & enjoy!
    Cathy
  • beardog03
    Um yeah...
    What Russ said !
    You , um...know how to , um give good advise there Russ...!
    I was going to get to that , really....!!!!!
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • dorokusai
    dorokusai Posts: 25,576
    If you have a single cable going to your subwoofer and it's working....move on to the next project. You don't need a splitter or another cable for your subwoofer.
    P.S. I apologize in advance and welcome to the fray.
  • Samantha31
    RuSsMaN wrote: »
    Cheers,
    Russ
    LOL Russ, I already have 4 new manuals with 3 new remotes, and you want me to read more :-)
    Buy the way...what do you guys consider to be the best unversal remote?
    Thanks again for everything!
    Sammi
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • Polkitup2
    Polkitup2 Posts: 1,642
    I don't know if it is the "best" remote, but the Harmony 880 remote is darn good.
  • engtaz
    engtaz Posts: 7,669
    Harmony 55O can be had for $79 on Amazon. I use this remote and like it.
    engtaz
    engtaz
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Oh sammi, how I love you, how I love you, my dear ole sammi........
    Sorry:o I could not help it.
    Welcome to Club Polk. Oh yea, as you can see I am nuts. I would use a digital cable for sound.
    RT1
  • peffy03
    peffy03 Posts: 50
    i use a sony remote commander with a touch screen you can get these online for under 100 and they work great. they have 4 ir sensors to send signals and the range is incredible. also learning commands is really easy. the touch screen has buttons you can change the text on so you can add commands your other remotes have that many universals dont.
    -Jeff
    My System:
    Onkyo Sr604
    Carver 125x2
    Polk Rti 10 (biamped)
    Polk Monitor 30
    Polk psw10bk
    Polk Rti6
    polk CSi3
    Monster ripoff wire
  • dorokusai
    I'd throw another vote for the Harmony remote control.
  • xandra
    xandra Posts: 291
    I prefer Universal Remote RF-20 (or 30) over the Harmony (I have 890?).
    Here's why...
    Universal Remote brand (RF-20) Cons:
    * you have to do the standard code lookup.
    * Commands/butttons are 'device type' generic, so they may or may not apply to your specific device.
    * poor backlight
    Pros:
    * Extraordinarily easy to program - I've yet to find something I can't do in seconds. It's a piece o' cake to add macros, rename commands, reassign buttons to suit your needs.
    * Very reliable - maintains your settings for a long... time should battery go.
    * Can copy your stuff from one remote to another (very useful when you have similar devices in different locations)
    *extremely powerful wide beam, (works well thru my cabinet's glass doors, even when misaimed and blocked by framing)
    * Has cheap optional RF 'PowerBlaster' for operating stuff up to 100' thru walls etc.
    Harmony Remote Cons:
    * Logitech's software is IMHO:gawdawful, uninintuitive and SLOW. - I personally can't bear having to go back to the computer just to change one simple item. f anything requires manual tweeking - it's very awkward.
    * There aren't as many consistent buttons, so: it's hard to develope an instinct as to what's where, and you end up needing to scroll page after page.
    * Pseudo macros on first page that appears with default buttons of "Turn on Cable, DVD, etc" is essentially pointless unless the bulk of your devices have dedicated On and Off Buttons (rather than a toggle) you're in for a real pain, if you accidently hit a button, or dare to use another remote...
    * You need to keep the device in powered cradle... and STILL have to replace batteries.
    Harmony Remote Pros:
    There's one but it's significant: It really does automatically add all model specific commands (rather than generic device commands)
    Oh yes, there is another, they've got phone tech support.
    UPSHOT:
    UPSHOT: in the end it was far quicker and easier to program the RF20
    But Like most stuff your choice is personal,
    IF you really desire the Harmony's Advantages, it's likely you'll prefer a Harmony.
    LR Setup:
    Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
    Onkyo 705 & Denon 3808ci Receiver, Onk 875
    Parasound 2250 Amp
    Sony 26" KDL series Bravia LCD
    Panny DMR-EH75 Recorder
    Panny DVD-F87 (5 disk DVD player)
    NAD T585 (DVD/SACD)
    Yamaha DVD-C961 (5 disk SACD/DVD)
    SciAnt Explorer 8500HD Cable Box
    Orig & 5Gen iPods, , Wii
    Plans/Fantasies:
    • 400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
  • McLoki
    McLoki Posts: 5,231
    beardog03 wrote: »
    For the RM speakers you have, you really want to set the crossover at about 150. (test up and down one setting from there) (the RM series has a crossover built in to protect the woofers and they won't play below 150hz. That is why they recommend the speaker wire method of hooking up the sub. (When they first started recommending it, most AVR's did not have adjustable crossovers).
    I use optical from my HD-DVD to my preamp. If your AVR has inputs for HDMI, use the HDMI cable from your DVD - to AVR - to TV. HDMI is the only way to pass high definition sound to your AVR. (or pre-outs, but we won't go there right now) If it is a standard DVD player - sorry, Toslink (optical) is fine.
    Welcome to club polk. If unsure about any of my answers, (or anyone elses for that matter) just ask for clarification. We all started where you are now...
    Michael
  • mark090852
    mark090852 Posts: 998
    I can highly recommend the Harmony 1000 touchscreen remote. It works beautifully for me. I don't have any of the issues that Xandra seems to experience. The software is very easy to follow to set up the remote or make changes. One press of an activity button such as "Watch a DVD" and it powers on all the appropriate devices and sets the proper inputs. All my devices have power on power off toggle switches and there's never been a problem setting up the remote to work properly. I can jump from one activity to another with one press of the button and it powers off what isn't needed and powers on what is needed.
    If you think you might go the Harmony route be sure to check around online for the best price. List price is $499 but you can get it for WAY less at Amazon and some other places.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • Samantha31
    Wow!!! Thanks again for all the quick and informative replies! Due to the cost of the equipment I just bought last weekend I may have to pass on a universal remote for now. Besides, a wall mount is next on my list. I think I may just duct tape all four remotes together for the next couple months :-)
    As for the system it seems to be working fine...great sound...until I somehow mess up my settings on this %#%&^&* Yamaha 6030 receiver :-)
    Thanks again everyone!
    Sammi
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • McLoki
    McLoki Posts: 5,231
    Cheapest place I have seen for wall mounts is MonoPrice. Be sure and pay attention to their customer reviews on the products you are thinking about. Some are really great for the price, others - you seem to get what you pay for.
    I have been very happy with all the purchases I have made there. (1 wall mount for a bedroom tv and some HDMI cables.)
    Michael
  • Samantha31
    Thanks for the tip. I will have to check if they deliver to Canada...
    If I lived in the States and got the prices you guys have I would own one hell of a system! As it is my brother can't believe his little sister owns a better system than he does :-)
    I have 25 days left to return something from my system I don't like and was wondering waht the gurus on here think of the Denon A/V Receiver (AVR-588) as opposed to my Yamaha HRT 6030??? The Denon is on sale and is a 7.1 AVR
    Any thoughts?
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • Pauly_9
    Pauly_9 Posts: 2
    hey guys i know this is not on the topic............just wondering how would u go about installing a 12vcar stereo to the home (240v AC) and would there be any interferance with the audio clarity??
    Thnakz alot
    cheers
    Paul
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    Samantha31 wrote: »
    Sammi
    ALL of the harmony remotes are great easy to setup easy to use.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Pauly_9 wrote: »
    Thnakz alot
    cheers
    Paul
    Paul I answered your question on the other post.
    Welcome to Polk Forums. :)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Samantha31
    edited December 2007
    So today I figured out how to re-assign my receiver's CD optical input to DVD optical input...and just to show off I renamed the input HD-DVD... Weeeeeeeeeee
    LOL - 2 weeks ago I had these components and empty boxes all over my family room and was about to pack them up and take them back :-)
    Thanks for everything guys...and gals ;-)
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • lightman1
    lightman1 Posts: 10,797
    Now sit back and enjoy the fruits of your reprogramming. But it never ends there......:)
  • cfrizz
    Terrific! Enjoy Sammi!
  • obieone
    obieone Posts: 5,077
    Welcome to the forum.
    As far as upgrading your recvr. goes, I have a Denon, it has a BUNCH of features.
    I'm not trying to suay you either way, but I have seen comments-not here-from people that thought the Denon was too confusing to work with. I can understand that.
    I've had mine for 2 years, and still haven't maximized it to it's full potential
    With that said, if you've got a handle on the Yamaha, leave it and enjoy it.
    Good luck
  • Samantha31
    LOL ...thanks for the advice
    I was thinking the same thing last night. Starting to get this thing figured out, don't want to go through another manual anytime soon :-)
    Sammi
    Yamaha HTR 6030 AVR
    Toshiba HD-DVD A30
    Sharp - Blu-Ray
    Polk RM6750 5.1 HTS
  • ninerbj
    ninerbj Posts: 870
    Welcome Samantha. Enjoy your new toys!
    "she had the body of Venus, with arms."
