Sub problems and all that jazz...
zombie boy 2000
zombie boy 2000 Posts: 6,641
edited November 2007 in Speakers
As you're probably aware, I've been trying to set my Dad up with a quality HT setup. Just as we're about to hit the last nail in this coffin, we realize his sub is DOA. Powers up, but no action. Currently using the line-in with a single RCA. Have yet to check with wires running to the fronts. It worked when he last used it. Doesn't work now. Switched out AVR's. Same results. blah blah blah Any ideas?
Post edited by zombie boy 2000 on
  • venomclan
    venomclan Posts: 2,467
    Sounds like it is not excepting the signal through the RCA and may not be going out of sleep mode. My old Cerwin Vega had this problem sometimes.
    Try the speaker cables and see if that changes anything. If not, take it to your place to see if you can get it to work in your system.
    Also check his AVR settings to see if he accidentally turned off the sub output on the menu setting. I have seen AVR's and pre/pros reset their settings sometimes and if the sub is set to off, it may be that simple.
    Venom
  • zombie boy 2000
    Tried it with a different rig with same results. Powers on, but no juice. If I have to pop the hood on this biznitch, what next?
    And btw.... how's Superman the Pooch?
  • dorokusai
    dorokusai Posts: 25,576
    Open it up and check for a blown fuse on the PCB.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    I know this may sound dumb, but did you try a different RCA cable?
  • zombie boy 2000
    Gracias... same RCA cable, but same problemo. Good advise Doro. So we're popping the hood.
  • dudeinaroom
    I'd try a differnt cable before opening up, cable could be bad
  • zombie boy 2000
    Cable's not bad because it works on two other subs. If the powerlight comes on, could the fuse still be blown? I know that's probably a dumb question....
    There's also a faint response from the woofer. Barely.
