Pioneer sx1250 & ipod
steve70
Does any one know how i can get my ipod docking station to feed into my pioneer sx1250? i plugged into the aux, tape and phone inputs buy no sound came out?
Thanks,
Thanks,
Post edited by steve70 on
Best bet is to go directly from the iPod headphone jack to one of the inputs on the receiver via a Y cable splitter...1-Mini Plug/2-RCA Plugs. NOT necessarily the one pictured here...but this is an example:
"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
shack's got it. They can be had at most stores and cost as little as a few dollars to Monster's $30.
I've gotten best sound out using Apple's cables (Marware also makes excellent ones) prices similar (cheaper than Monster). I've never been able to find good quality standard mini plug/RCA cables (most come with miserable insulation)
Couple other notes:
* You need to turn the sound on your iPod way up...
* Some docks only work with Apple/Marware type cables (be sure to get correct type for your dock, others only work with mini plug/RCA type. Be sure to check your docks' manual.
*Lastly, you didn't mention what model iPod you have - I understand the latest version (Classic) uses a different dock, and video out has changed to component. Don't know if this affects functioning or cabling of audio.LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
Or, if possible, get one of the docking cradles that has RCA outputs on it. A little more expensive but I've heard from various people that they sound better coming off that plug versus the 1/8" (or smaller) jack. I don't know since I don't own one so, YMMV.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
