Wanting to upgrade but unsure....
JoshParsons84
JoshParsons84 Posts: 565
edited November 2007 in Electronics
I'm moving to a bigger place with a larger area for my HT and wanting to upgrade to maybe RTi or LSi (not sure yet). I'm just wanting to know to make this leap from Monitor 40's what should I do first?
Post edited by JoshParsons84 on
  • Early B.
    Early B. Posts: 7,900
    Start with the brains of the operation -- the pre/pro or receiver. If you're gonna upgrade to Lsi's, you're gonna need separate amplification.
    "God grooves with tubes."
  • McLoki
    McLoki Posts: 5,231
    Get moved into the bigger place. Once there and you know what you are working with (both budget and room) - ask again.
    Michael
  • JoshParsons84
    Well serperate amplification is key in really any and all upgrades correct? Even if I would upgrade to some Rockets or something like that I'd have to have better electronics right? Should I upgrade from my Onkyo 503 to a low level receiver with pre-outs or just get a pre/pro now and then save up some more and get an amp? And if so what pre-pro's should I be looking at? Not really anything fancy for the time being just something to get by.
  • McLoki
    McLoki Posts: 5,231
    McLoki wrote: »
    Michael
    Cant answer any electronics questions until we know what speakers you are working with. Can't help with any speaker questions/suggestions until you know what your room will be like.
    For now - all you have is questions and no answers. Assume it will cost money and start saving now. When you get the new place, let us know what you saved up. Until then - read more, post less. (I really am trying to be helpful here....)
    Michael
  • JoshParsons84
    OK that's fair enough. After we get moved into our new place I'll see what potential the room has and how much the little lady is gonna let me spend on a HT system then I'll get back at you guys. But just food for thought the electronics are just as important as the speakers so that's something for me to keep in mind.
  • beardog03
    beardog03 Posts: 5,550
    Get a Parasound 5 ch amp !!
    get a pre/pro that has all the bells and whistles that you want...it`s the "brain"...don`t skimp...look forward into technology as far as you can as far as what you want (TV, AMP,SPeaks, etc.)
    As Mcloki said...
    Check out your space..
    make a real budget....not just "somewhere around here" kinda thing...try to be as realistic as possible..
    are you making a HT/2ch all in one rig, or mainly HT ?
    Make a short list , including cables, I/C`s, gear, speaks.....
    Once you have measured and got a clear understanding of your room,budget, and main use for the system....
    Then we can formulate a game plan..
    I know how exciting it can be to put a brand new system together...
    I also know how frustrating it can be..
    Try to Take your time and do it right the first time....
    It will pay off in spades..
    Congrats on the new digs by the way..!!
    Are you buying or renting...if you don`t mind me asking
    if you do, just tell me anyway...!!!!!!!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Ethancf
    Ethancf Posts: 478
    beardog03 wrote: »
    I'll second that Mr beardog! ;)
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • beardog03
    THat`s a nice amp ya got there !!!
    I still want that 7100....:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • JoshParsons84
    Well for now we'll be renting. But hopefully it'll be one of those things that turns into a rent-to-own land contract.
  • Ethancf
    Ethancf Posts: 478
    beardog03 wrote: »
    I still have to update my other thread with pics...stay tuned...the 7100 is sooooo sweet. :D
    THE SYSTEM
