Video guru question...
steveinaz
I suck at video, so here's my question:
Do HD-DVD/BluRay players also play Standard Definition DVD's?
Post edited by steveinaz on
Absolutely. In fact, they play them better than a standard DVD player. Better SQ & PQ.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
As far as I know, everyone of the blu ray and/or HD-DVD players will "downconvert" to standard def discs. And I think they all serve as upconverting players as well, meaning they improve SQ and PQ trying to "mimic" HD.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Cool, thanks fellersSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
You are correct, they also upconvert. Most movies will only upconvert if you have it connected through HDMI though, I found this out the hard way. Sony DVDs are the main culprit, but I have also found a couple of others along the way...
Not a guru, but:
All are backward compatible with DVD. Using the upscaler in a new player may or may not improve PQ, and is usually only available via HDMI, not component. Your Sammy may like the signal better if it's 480i/p or it might like the 720 signal better. I'd try the upconversion (720) from the player first, watch a scene that you know well, then send it 480p and see how the displays scaler handles it. Chances are in your case the new-tech player will do it better, but I'd try both. You don't want to process the signal twice, so send it 480p (DVD), then 480p upscaled (x1.5) to 720 which is native for the Sammy. I doubt you would get better results trying either 1080i/p.-Ignorance is strength - -
Exactly! It all depends if the TV or the player has the better scaler.
Cool. My Samsung is 720p native, this is the resolution I run my Denon 2910 at, via HDMI. The picture is awesome--just wanted to make sure a new HD player would play the "old" stuff.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
