RT800 Speaker Combo
I was curious if anyone had any experience or even just an opinion with this combo. I'm looking at a pair of RT800 (I don't think they are RT800i) on CL for $150. First off, I would like to know if you guys think that's still a decent price if they are in good shape and perfect working order. Second, I was trying to decide how to combine them with the rest of a 5.1 setup. I see on the Polk FAQ that the CSi5 is supposed to be a good match for a center channel. I have read in the forums that the CS400 is the best match, but I am unable to find any on ebay, audiogon, CL, etc. Anyone know if they would work together? My only concern is that they are different tweeters. Additionally, I was looking at the RTi6 for surrounds. These are all being hooked up to a Sony STR-DG1000 receiver and even though I know it's not the same as purchasing a separate amp, I will be biamping the RT800s with the remaining two channels of my 7.1 setup since I'm only using 5.1. I figure it should help a little bit. What do you guys think? Thank you for any advice you may have.
Post edited by solidus28 on
Thank you for the warm welcome and the response! I've been reading the forums for a while trying to decide what to get and had really been looking into rti8s, but I just felt like I couldn't pass up the RT800s for $150, quite a bit cheaper than a pair of rti8s. If I am unable to find a cs400, do you think the csi5 would be pretty close or should I not even bother with it? I'm going to start looking for some RT55s and see what I can find.
Ok, another question. I found an auction for a CS400i. Will the CS400i match a non i RT800? Would this be a viable option?
Sorry to ask so many questions, but I have another one. As I mentioned, I was previously looking into the rti8s. Going with your above price estimates, I could get a pair of rt55s, the pair of rt800s I found and a cs400 for around $650 rock bottom. So that could potentially be anywhere from $650-900 probably. Now, I could get a pair of RTi8s, a pair of RTi6s and a CSi5 for $1015 or even upgrade the RTi8s to RTi10s for a total of $1085. Would it be worth a $200-300 for the RTis? If so, what's your opinion on RTi8 versus RTi10 if I will have a sub in either scenario. I've seen a lot of threads where RTi10 is great if you don't have a sub, but is it that much better if you do? Is it worth a $70 upgrade? Or is all of this moot and the RT800s are a better speaker and I should just stick with that regardless of price?
Rti Series is on sale almost everywhere because of the new RTiA series. Could be a good time to get some Rtis.Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
Well, I guess I ended up solving my problem. I appreciate everybody's input. I went by Sound Advice (or Tweeter) and they had BOGO on the RTi10s because it's the last shipment they are getting. Basically, $240 a speaker. I was curious about the RTi8s but they only had a couple floor models left and they were still going for about the same as the BOGO RTi10s. I ended up buying 4 of them and have ordered a CSi5 from onecall.com for $199 that should be here Thurs. I can't afford to get external amps for the ATM, but it should still sound great compared to what I've been using for the past 8 or so years. I had 4 puny Sony Satellite speakers and a puny Sony center channel. I will admit, they still sound fine, but I'm sure there's no going back after I get done hooking up my new speakers. What amps would you guys suggest for RTi10s and a CSi5? I've never had to purchase amps for the HT before sine I had such small speakers. I'm not really familiar with brands even.
Thank you for the links, I've begun looking at some amps, but they will have to wait until sometime down the line. The last link you provided was quite informative. I can't wait to get home and finally see how these bad boys sound! I am probably going to run with a "Phantom" center channel until the CSi5 arrives on Thur., so I'll really get to see how the soundstage is on these speakers. I'm sure I won't be disappointed with these without an external amp, simply because my old speakers were maybe 2 inches wide and 4-5 inches tall. This should be a huge upgrade!
