Girlfriend's Dim Witted Dimmer Switch Idea
    mhardy6647 Posts: 35,033
    edited November 2007
    20 minutes?! mmm... if it takes 20 minutes, maybe you shouldn't put it in yourself...
  • vonnie123
    vonnie123 Posts: 326
    jdhdiggs wrote: »
    I didn't see where you two are married. I say dump her now while you have the option and date someone more amenable to your idiosyncrasies.
    The above option has already been mentioned, however, if she is a good match for you, get the dedicated 20 amp circuit for your system; as stated, it's a win-win. Dimmers are major noise generators as you can see. Good luck.
  • dbnh
    dbnh Posts: 194
    I look forward to reading more about events in this couple's life together, including perspectives from the original poster. It's refreshing to read firsthand about the flexibility of those in the now generation.
    "First came the dimmer;
    then the verbal "ouch";
    then came "honey,
    you can sleep on the couch!" :eek:
    Peace, y'all. :)
  • bsoko2
    bsoko2 Posts: 1,449
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Tell your girlfriend that the only dimmer that's going to be installed in your house will be on her yapper.
    Then go plop on the couch, turn on the football game, and direct her to get in the kitchen and make you a sammich.
    When she delivers your sammich, tell her to "hit the showers" because you might be in the mood for a little luvin' during the half-time show.
    Trust me.
    She'll forget all about the dimmer.
    P.S. It seems as if she might be a little hard of hearing, so be sure to snap your fingers at her when she's receiving commands. That'll help get her attention.
    SCompRacer Posts: 9,112
    Sounds like your girlfriend is more like a fianc
  • Manilaboy
    Manilaboy Posts: 49
    Just make sure the electrician doesn't make regular visits while you're away ;)
  • Yashu
    Yashu Posts: 772
    I have a hard time understanding why an electrician needs to be called to install a simple dimmer. *grunts* That is a typical female... they would rather pay someone else to do what A: you CAN do yourself, (seriously, you can, it's not hard, you already have a computer on the internet, you can google how to do it), and B: would rather pay someone else than to CONVINCE you to do it yourself.
    See, this is typical passive aggressive behavior, you don't want the dimmer, so she is going to fight back by hiring someone to do a 10 minute job that you could do, but don't want to, thus humiliating you in the process (so she thinks). Most women these days (not all, but most western, and more typically american), are brought up from day one to learn the "other way", this passive aggressive **** that really gets us men all pissed off, and then rightfully so or not, starts a fight, where the real action takes place... and then they can claim that you started the fight, leading to YOU apologizing to her for what she set into motion in the first place.
    We are a nation of men raised by women, so men just deal with this crap and either let it get to them, brush it off, or otherwise accept it as "typical" female behavior (like I did, see what I did there?).
    How do we get out of this vicious cycle? Find the right woman, the yin to your yang, as it were. There is nothing shameful about putting your foot to the ground and saying no. IF it is your place, she has no business going behind your back and hiring an electrician... how can that kind of relationship maintain itself? Where is the trust? She should be able to trust that you will listen to her and consider her wants, just as you should be able to trust her not to go behind your back and do something against your will.
    The dimmer, is the least of the problems here, my friend. Put your foot down and keep it down, and if she loves you, she isn't going to leave you over a dimmer, and in the mean time, you can arrange for the dedicated line, and once it is installed, put the dimmer in when she isn't around so she comes home surprised that you actually did listen to her afterall. Patience is a virtue.
    tonyb Posts: 33,072
    Your reading alittle too into this Yashu.......call the electrician.....install the dedicated line,and the dimmer....you get what you want....she gets what she wants....win/win.
  • rskarvan
    rskarvan Posts: 2,374
    Yashu is right on target. The least of this guys problems is the dimmer switch!
  • janmike
    janmike Posts: 6,146
    tonyb wrote: »
    Agreed.
    What's going to happen when they cannot decide on which house to buy.
    Michael ;)
    NORTH of 60°
    tonyb Posts: 33,072
    It's called "compromise" gents.....something that happens in every happy :)relationship.
  • Sansui
    Sansui Posts: 372
    zx_toth wrote: »
    Ill probably let her have her dimmer switch ...
    Tell the electrician that you want the type of dimmer switch that looks like a regular light switch. The ones that have a round knob which you push to turn on and rotate to adjust "dimmage" won't last nowhere as long as the other type will.
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
    janmike wrote: »
    Agreed.
    It appears that has already happened.
    zx_toth wrote:
    and we just bought a house together
    zx toth wrote:
    I may have to change my a-hole act tommorow morning to something more pleasant ...
    I know it is funny how I stomped my foot down without knowing what a dimmer switch did that was detrimental to the sound…
    Sounds like Zsolt can handle this all by himself. Is a spirited female such a threat to some of you? Maybe we should go back to foot binding?
    I recall having all sorts of stupid arguments like this early on with my wife. Idiotic power struggles. Things got better after I accepted her as an equal partner in our marriage. The oak tree and the cypress grow not in each other’s shadow. Tony is right. If you can’t compromise, get out now before children are involved.
  • dbnh
    dbnh Posts: 194
    Sansui wrote: »
    I've found the above to be true as well.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Yashu wrote: »
    That's is the funniest line I've read in this thread.... The mental picture I get of the argument over a dimmer then her storming out the door is priceless.
    Defiantely suprise her and get the dedicated line as well as the dimmer.....might get you a little extra that night or it might get you sleeping on the sofa cause you did it without consulting her.
