2 subs
gracenrich
Hi All
I have 2 subs a Polk 350 connected
and a larger M&K not connected.
They are approx 8 ft.apart.
What would be the best way to connect them?
I am now using the Polk way.
Would it be beneficial to connect them?
Thank You:rolleyes:
Thank You:rolleyes:
R.Gordon
Post edited by gracenrich on
i allways use lfe always
dasy chane the 350 -
Buy a Y splitter and run it off the LFE and connect a sub cable to each sub."What we do in life echoes in eternity"
SVS -
That's not daisy chained, that's parallel. Daisy chained is series (out to in, same device out to the next in, etc...).
I think Doc will back me on this one, but you should have them all driving from a single point. Stack those babies and find what you've been missing!
Wally -
why daisy chain instead of how Dr recommended. To me.. the y cable from the LFE would make the most sense to me. but other ways may work too.PolkFest 2012, who's going>?
same thing but if the in out is cheap you might lose a little sigonal. it is cheaper you dont need a y spliter. eather way will work. it is your choice. when i was testing my new amp with my old subs and some other speakers i used the in/out method and worked fine.
That was the only reason I recommended a y splitter instead of jumpering the subs - the amp can cause a signal degradation in some cases (not always)."What we do in life echoes in eternity"
SVS
