Am I harming my equipment ???
shaggyb
The speaker wire I ran for my rear surround speakers did not have any sort of markings on the sheathing to help me determine a positive vs negative wire. The wire was run above the ceiling drywall in my basement, so it would be almost impossible to trace it back to keep one marked as a positive lead.
I want to hook up my new surround speakers, but am concerned that I may cause damage to them not konwing if the signal is crossed (negative feed from receiver to positive input on speaker, etc.)
AM I AT RISK OF DOING PHYSICAL DAMAGE TO MY EQUIPMENT, OR AM I SIMPLY LOSING SOUND QUALITY ???
I know the easy answer is to get new/better wire, that would have a marking or color coding of the wires to determine polarity. I was on a tight budget when I made my wiring decision (No excuse...I know) and admittedly tried to cut corners....(Now I pay for that choice)
Any information owuld be greatly appreciated
Post edited by shaggyb on
No, you will not harm anything.
Pick up a Fox and Hound, find a used one, borrow one from work / a friend and you can get it squared away in no time.
http://www.mcminone.com/product.asp?product_id=74-335&catalog_name=MCMProducts
Cheers,
No damage, just polarity. If you had a multi meter that would reach, you could check that way.
Hook your surround wires to you reciever's left and right front speakers. Switch reciever to stereo. Turn on music, check polarity.
Or if you had DVE or AVIA disk. Real easy to check.
When you get it right... MARK IT!!!!Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I guess I am not to sure what I am supposed to do ???
Am I checking for current ?? What exactly will the multimeter show me ?? What am I looking for ??
Please help !!!! -
use a volt meter and on one end hook up a 9v battery than go to the other end use the volt meter which ever one is + mark it than go back to the battery and mark the wire that was hooked up to +. there ya go I do it all the time.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I found a different trick online using a 9v battery, and hooking it up to the ends of my wire runs (at the receiver). If the woofer jumped out when connected, thw wires were hooked up correctly, but if if jumped in, then it was reversed. i used this to mark my positive and negative leads and should be fine until I decide to upgrade the wires
Thanks to all for the help
