Acoustic Research, good budget stuff or teh suck?
Yashu
Yashu Posts: 772
edited October 2007 in 2 Channel Audio
I am curious at what you guys think of AR cables, speaker and ICs. I ask because I see them every now and again at the big box stores, and wonder how they stack up against other "high end" cables. I would never spend a dime on monster cable, and AR seems to be the only other brand worth a damn at these stores...
I can tell you what I personally think about their speaker cable (it's not bad), but I don't know much about their ICs. Yes this is a subjective question, so give me your subjective opinions ;)
Post edited by Yashu on
  • beardog03
    beardog03 Posts: 5,550
    edited October 2007
    I think they are about the same as monster...just a different brand
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Yashu
    Yashu Posts: 772
    edited October 2007
    They don't have the reputation of suing anything that moves, overhyping their products, and using other shady tactics to sell wires. So you are saying they sound like monster cable without the evil?
  • Face
    Face Posts: 14,340
    edited October 2007
    In my experience, their cables suck.
  • steveinaz
    steveinaz Posts: 19,545
    edited October 2007
    Never heard them, but they tend to get pretty good reviews. Sam Tellig of Stereophileonce classified them as "the last cable you may ever need." FWIW...
  • shack
    shack Posts: 11,154
    edited October 2007
    I've got some AR stuff in my HT rig (sub cable, optic cable). Not bad, not great. I would rate them as good as monster or RS Gold and better than the generic stuff from the likes of Philips or RCA that you find in Wal-Mart, Target, etc.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2007
    trolling..............there is plenty of information about AR cables, might try the search function.
    RT1
  • Yashu
    Yashu Posts: 772
    edited October 2007
    At least you admit this time you are trolling... that means you are getting better.
    Even their low end ICs are directional... I found that interesting. I bought a set to test all of this.
    Their low end 12.99 cables are not as pleasent sounding as my wireworld cables, but they can compete with my VampireWire cables on resolution and transparency. They are a good value, it seems. I have never heard monster cable because I refuse to buy from them, but AR has at least impressed me for what one can get for $12.99. Their higher end model, I didn't hear a difference... both directional, both the same amount of copper, but the difference in shielding. I didn't see any reason not to just get the cheaper ones for normal runs.
    Their speaker cable is great, actually... I bought it on sale, 12g wire for really cheap, and have used it all over the place. I would say that, if I had the choice between the DIY Home depot cable, and AR 12g, I would pick the AR... infact, I would pick the AR over a 4 conductor boutique cable that I used to use for my main system. The fact that they are there next to monster cable, warrents their purchase, the more sales that monster loses the better, IMO. So, in closing, I think they are a good cable for a bedroom or 2nd system that can be easily found without going through the net or a boutique shop.
  • Willow
    Willow Posts: 11,228
    edited October 2007
    I had a whole bunch of AR cables, from their P series to the pro Series II. I have not owned the Master series. They are decent. Flexible with decent connections. I prefer AQ over them. They are about the same if not a little better than Monster for less $.
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2007
    on par with mid-$ monster, below RS Fusion.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Yashu
    Yashu Posts: 772
    edited October 2007
    RS as in Radio Shack?
    I actually liked their older gold series, the ones with the black wire cover and the gold ends... the new gold series, is just so so (the grey ones)... the jacks are low quality, and not to fond of the sound.
    Where are you getting these fusion cables, if by RS you mean radio shack?
    As you can see, I am a budget cable experimenter.
  • Jonesy
    Jonesy Posts: 189
    edited October 2007
    I've been buying the cheap blue IC's for a few years now. They seem to be a good value as they're well constructed and much cheaper than Monster.
  • Yashu
    Yashu Posts: 772
    edited October 2007
    Those are the most recent ones I tested out. I bought one of the more expensive ones, and thought "hey, I could have two for the price of this and there would probably be little difference), and it was true. The blue cable is just as good, with only slightly less shielding. Cheaper than monster, and for their market, it makes me wonder how monster is still shafting people, but they do have a rather large marketing budget.
  • Jonesy
    Jonesy Posts: 189
    edited October 2007
    Look on ebay. There is one particular seller there that I've bought many of the 'blues' from for even less than BB. They seem to have just about everything, although most of them are delivered sans packaging (which dosen't bother me one bit).
