Best polk speaker for music
mailman23
mailman23 Posts: 93
edited October 2007 in Speakers
Which polk speaker is best for music(rti 10/ rti 12 or Lsi 15)? I listen to all kinds of music, but mostly rock and top 40. On a side bar, I want to get a a/v in the 1000 range that has hdmi upconversion and switching. I was looking at the onkyo 805 and the yamaha 2700. Any suggestions?
Post edited by mailman23 on
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited October 2007
    The LSi 15's would be better for listening to music but you I would suggest you get a separate amp to power all three. I was not happy with my RTi 10's for music.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • engtaz
    engtaz Posts: 7,669
    edited October 2007
    LSi15's hands down. Amp is a must and make sure it can handle 4 ohm load. Get a pre amp and a Adcom 555 or 555II, Carver, Outlaw,or other amp that will run you LSi15 very nicely.
    Good Luck on your choice,
    engtaz
    engtaz
  • PADZZ
    PADZZ Posts: 83
    edited October 2007
    You can get the new Yamaha RX-V1800 for less than $1000 shipped. It's awesome.
  • dkg999
    dkg999 Posts: 5,647
    edited October 2007
    If music is your main concern, given those choices I would opt for the LSi15's. Can you run them with the Yamaha HTR's referenced, yes you can. Would they be the best choice, not in my opinion. IMHO the Yamaha HTR's don't mate well with the RTi or LSi line of speakers, from a sound quality perspective. I would opt for a Pioneer Elite or Marantz HTR in the price range you noted.
    Also, as previously stated, using a separate 2 ch amp is going to be the best to power the LSi15's. You could use the HTR until you find a good deal on your amp of choice. Anything from Adcom, Parasound, B&K, Outlaw, Sunfire, etc. would work well.
    DKG999
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2007
    Check out Pioneer Elite receivers. Try to find the VSX-94TXH should be right around your budget.
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    the yamaha really doesn't mate well with polk's? Is that true? Has anyone else experienced this problem? I was really leaning toward the 2700 or 1800. They have hdmi switching and upconverting
  • janmike
    janmike Posts: 6,146
    edited October 2007
    My personal opinion when I owned a Yamaha receiver (RX-V1500) was that it was on the bright side. You need to listened to that combo yourself and make the decision. You may like it and that is all that matters. My only question would be does the Yamaha have enough power to make the 15's sound good. If it were me I would look at something else other than the Yammie.
    Michael ;)
    NORTH of 60°
  • mailman23
    mailman23 Posts: 93
    edited October 2007
    The yamaha would be a temp. source of power for the lsi 15's. As soon as I could afford I would pick up a two channel. I just can't afford the speakers, receiver and two channel all at once. Would the yamaha handle 5.1 with a lsi center?
  • fatchowmein
    fatchowmein Posts: 2,637
    edited October 2007
    I had my 15's mated to a Yammie HTR. World of difference when I added a separate amp. Yammie ran cooler, too.
    I was listening to music at -18. After the amp was added, -38. I'd go deaf if I left it at -18.
  • McLoki
    McLoki Posts: 5,231
    edited October 2007
    I think the LSi mated with a pre that is on the bright side of things would be a great match. (assuming the Yamaha is just bright and not crap - I don't really know about that.) The RTi's and a bright pre - not so much.
    Either way - it will sound much smoother and less strained with an amp in the mix. Also keep in mind that the LSi's are revieling enough to reward you with every upgrade - and punish you with each corner cut.
    Michael
