LOw Volume
I'm a loud kinda guy . . . I like it loud . . . the soft music is for elevators.
I didn`t say soft, I said low volume !!
that`s what I mean...it doesn`t get "soft"...it`s still tight and crisp at low volumes...
she does great at medium and high volume also....
she even hits concert level and retains clarity without distortion or compression....:cool:Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
"hearingimpared," low volumes are out!:rolleyes: -
so medium is low, high is medium, and concert is just right !!!
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Right on Brother.
Seriously, I know what you're saying Bear. I'm quite happy getting my groove on at lower levels.Political Correctness'.........defined
President of Club Polk -
Ruthie just came in and asked if I would turn it down..!!
It`s down already..
If I turn it down any further it will bear-ly audibleCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Buy her a box of foam ear plugs...........then get yourself a blanket and pillow for the sofa.
looks like I`m headed in that direction !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I listen at lower volumes. Putting the tubed buffer after my DAC really made the difference. See I am one of those PC audio guys... but I built my PC to be dead silent. MY ears are VERY sensitive, and I cannot stand loud noises, but I do not want to have to "strain" to hear detail.
It is kindof hard to explain, but I do get the idea of "low volume" and I enjoy it. Some of the time I savor the most is when the volume is on the lower end. I am sure I could get by with a much less powerful amp... that is, if I did not use it for 2ch HT occasionally. I am sure my nearfield monitors draw only a couple watts when I am really enjoying music, however my towers definitely need the power when I watch movies. The NAD though... it does seem to do very well for a SS amp once I put tubes into the chain.
I have thought heavily about having two separate systems even though they would be right next to each other... but for now, I am listening to John Abercrombie's "The Third Quartet" on a low volume yet I hear every detail as I type this. -
I'm good at low volume. I'm also good at medium and concert volume.
Same here. Low level resolution is important and is an indicator (to me) of a well put together system. I've gotten rid of a few pieces from the office rig that didn't have good low level resolution. I will say with the 5b's to get any bass you need to bump them to higher than normal listening levels (in the current room sitting about 4 feet away). With the 1C's even a notch above background level everything sound excellent even the bass is there.
At my house, hi volume doesn't happen often.
Tubes do seem to bring stuff alive at low to moderate levels.
I've also heard some passive preamps also help there.
Never had any time with a passive to find out."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
The TVC passive seems like a cool idea because of the transformers. It's passive yet I hear it does not sound thin like other passive pres.
Most of my listening occurs after the wife and kids are asleep. I crank it occasionally when, by some twist of fate, I'm the only one home. My system sounds great at low volumes after one free tweak. I'm powering SDA 2B's with a NAD C370 and a tube buffer (Yaqin with JJ/Tesla 6922 tube) in the preamp-out/main-in loop. When I first hooked up the tube buffer it sounded great once the volume was up a little but didn't seem to do anything at low volume. I also noticed that the volume control was extremely sensitive at low volumes. The NAD has two preamp outs - one with an adjustable gain. I changed the tube buffer to the preamp outs with adjustable gain, turned the volume up until it sounded good, and then turned the preamp gain down until it was as quiet as I will ever want to listen. The gain is turned down approximately 1/3 now. Problem solved! Now all the detail, punch, and warmth are there at low volume and the volume control sensitivity is gone. I don't notice any difference at high volume except really loud used to be around 10:00 on the main volume knob and now it's around 11:00.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Dared SL-2000a (Siemens & Halske TM 12AT7WA's, Brimar 5Z4G)
Jolida JD-100a (Sylvania BP TM Gold Brand 5751's), NAD C275BEE, Blue Jeans
RTiA3, Onkyo TX-SR605 -
I have a music CD that has an inserted recording of jets landing at an airport on a certain track. It's absolutely wonderful in a salesperson demo.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Stew, I had the same problem as you when I put my buffer between the pre out and main in. Unfortunately my NAD does not have adjustable gain... It is interesting that you had this same problem. I wonder if one of the newer small NAD integrateds like the 320bee have this adjustable gain.
My Cary has R/L adjustable gains alsoCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I get that low level resolution with my Spectral pre.
Whether it's low, medium, or high volumn my system is very musical & satisfing. That's the beauty of a steller pair of monitors. They get it right no matter the volumn.
Good stuff Stew! Nice writeup, glad to see you posting and jamming with those 2B's.Carl -
Yashu - The NAD website provides images of the rear panel for all of their integrated amps. Unfortunately, it looks like only the C370/C372 have the adjustable gain. FWIW, I bought my C370 from audiogon for $400. They still show up occasionally.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Thanks Carl! I still can't believe the sound I'm getting from these after spending less than $1000 on upgrades (amp, tube buffer, CD player mods, crossover rebuild with TL mod, new tweeters).SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Stew... haha I had a feeling that would be the case. I bought my c350 and considered a 370 then... but man... I feel like it would be the biggest overkill in the world considering my speakers/habits/environment.
The c37x has two things now that makes it appealing to me... one was always the built in a/b speaker switch... and now there is adjustable gain.
Hey! I just looked and the seperate pre c162 has this adjustable gain too... I'll bet the c160 has it also... I may just pick one of these up and do it that way. My buffer is also a yaqin, if I do get a hold of one of these NAD units, what gain setting have you found to work the best? I am going for low to moderate volume performance.
Now I just have to find a used c160 for sale somewhere (I want to get the pre from the same generation as my integrated if I can... this is my OCD talking). -
Yashu - The gain knob has 11 dots going from min to max. If min is dot 1 and max is dot 11, mine is set around dot 7.SDA 2B-TL (Sonicap/Solen/Mills, Erse Super Q, Rings, Spikes, No-Rez)
1000VA Dreadnought
Thankyou stew... I am now looking for a c160 on AGon and ebay and anywhere else... so I think I will like havng the tube buffer in the full system chain will be nice. Right now, I am just supplanting my DAC... and it has pretty low output voltage... so I can only imagine the improvement on an output with appropriate output voltage.
Stew, you still around?
I finally found a c160 and am trying it out... the cosmetics are changed ever so slightly, where yours has 11 dots mine has 4 main ones and about 8 between each, but I am trying various settings, all an improvement over my integrated (being able to tweak the gain lets me hear detail that I never usually hear. Definitely a great pre, that is for sure.
Thankyou for this little tidbit that lead me to my c160. My low volume listening just got better that is for sure. -
My system is kind of timid at low levels. I usually listen from a third to half volume. Anything past one half my ears start to hurt after a few minutes, plus the lights start to dim.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
face,
got any pic`s of those killer Mac`s ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
There's a couple in my showcase. No full room pics till it's repainted and I put a new floor down.
http://www.polkaudio.com/forums/showcase/view.php?userid=78806"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
those are beauties !
I always wanted a pair of the mac mono`sCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
