Two 10's in series or parallel?
gwh
I have one of those recalled Polk subs that smoked (dual 10's), I'm about to mount an amp from a PSW 450. Should I wire the drivers in series or parallel?
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
That all depends on what the Ohm's of the subs are and what the Amp from the PSW450 can handle. Without that information... none can say.
True.....That's the info I need.That all depends on what the Ohm's of the subs are and what the Amp from the PSW450 can handle. Without that information... none can say.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
do you have or can you get a DVM? DC resistance is close enough (and with a predictable amount of error) roughly figure out a speaker's impedance.
agear list:
1 down, 4 up....
