More User Adjustable Components, Please...
  • ben62670
    ben62670 Posts: 15,969
    edited October 2007
    I have tone controls on my Pre, but it is usually set to bypass. If you have good music recorded bad then tone controls can be your friend. I am pleased that I have the option to use, or not use them which is usually the case. As mentioned above some environments can benefit from tone control. I think that tone control has improved greatly in recent years, and shouldn't be totally ignored by "purist".
    Ben
    heiney9 Posts: 25,432
    edited October 2007
    madmax wrote: »
    Don't have them, don't want them.
    madmax
    Ditto.
    I have found that tone controls are extremely limited and cover way to broad a freq range/dB level to be of any help whatsoever. Even parametric split octave eq's controls have a very broad affect on a 2 channel stereo recording.
  • Yashu
    Yashu Posts: 772
    edited October 2007
    is no reason to hop right in and screw up everything just to add a little shake or sizzle.
    I remove sizzle, never add... sizzle is my mortal enemy. Bass, I am not picky with, as most setups can produce acceptably defined bass... but the treble can give me a headache very fast. Now, on vinyl, it isn't as much of an issue, since the record has mechanical rolloff. There is only so many waves per inch you can pack onto a vinyl record.
