Help me find a good amp stand . . .
SolidSqual
With my new Odyssey Khartgo (Stratos Mod) amp coming soon, I've decided I need a good amp stand to show it off. Eventually I want to trash my crappy entertainment center from Target and display all my electronics on stands that make viewing possible. PLus, the open stands allow for easy access and tweaking.
I had something like this in mind:
http://www.audioadvisor.com/prodinfo.asp?number=SAEFABII
Or this . . .
http://www.audioadvisor.com/prodinfo.asp?number=SMAMP&variation=CHE
I want to stay within $100 per stand.
My other thought was to go to Home Depot and buy these solid cutting boards made of some very rich wood that weighs about 30lbs for $40 bucks a piece.
Thoughts?
Or this . . .
Thoughts?
Post edited by SolidSqual on
I like the salamander one better. It looks cool with those big spikes.
How much weight will they support. The Salamander looks nice but the other looks like it would support more weight.Michael
NORTH of 60° -
Here's a nice site for you to take a look at. A tad bit over your budget, buy they look awesome. http://show.audiogon.com/cgi-bin/fdm.pl?002&1171492309&item&Adona_corporation&4&5&6&http://cgi.audiogon.com/cgi-bin/fs_srch.plQQANYAAAApurlsrchAAEXYAAst26AAAAAAamp_stand"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
pearsall001 wrote: »Here's a nice site for you to take a look at. A tad bit over your budget, buy they look awesome. http://show.audiogon.com/cgi-bin/fdm.pl?002&1171492309&item&Adona_corporation&4&5&6&http://cgi.audiogon.com/cgi-bin/fs_srch.plQQANYAAAApurlsrchAAEXYAAst26AAAAAAamp_stand
Now that's a stand.Michael
NORTH of 60° -
The platforms are enough near my budget, but the amp stands are just too much. I'd rather spend the money on gear.
SolidSqual wrote: »The platforms are enough near my budget, but the amp stands are just too much. I'd rather spend the money on gear.
So would I, but my amp weights in at 120 lbs so the last thing I want is the amp hitting the floor suddenly even from a few inches.Michael
NORTH of 60° -
That's why I like the Sanus model on audio advisor. It may not be pretty, but it looks like a tank.
Hey, I think it looks ok. I would own it. There, done deal.Michael
NORTH of 60° -
Mike, how heavy is your amp?Michael
NORTH of 60° -
http://www.standsandmounts.com/index.asp?PageAction=VIEWPROD&ProdID=1194
Janmike: This one holds 200lbs. -
My amp is about 50 lbs. I think. Let me double check.
54 lbs.
Not bad if the rest of your gear is silver and you want to maintain a consistent look. Some do not care, I do.Michael
NORTH of 60° -
Does your amp get hot, I mean HOT. That may be a consideration.Michael
NORTH of 60° -
Maybe you should design your whole system around that stand. Sell every thing and start "de novo!"
I'm told it runs pretty cool.
SolidSqual wrote: »Maybe you should design your whole system around that stand. Sell every thing and start "de novo!"
All my HT gear is black. I purchased the stands knowing that. All of my 2CH gear is and will be silver. The stand will coordinate with the gear. Spending that much much, and I mean lots, I cannot help but think that it may as well look good because it sure as hell sounds good. Buy K-Mart gear, use a K-Mart stand. It would be like putting the cheapest tires on a Porche.Michael
NORTH of 60° -
In that light, I have used tires on my Mustang GT passed down from my brother's wreck.
Buzz kill. However, you make a very good point with which I agree. Beautiful equipment is duly appreciated with beautiful stands. -
Go you your local granite countertop manufacturer and have them make you one. You have a choice of edge treatments, stone colors, etc. They last forever, and even act as a heat sink for radient heat, though I imagine little heat would come out of the bottom of the amp. Should be around your $100 budget, or much less if you have a friend in the business. Granite slab is available in stock 3/4" or 1 3/16" thicknesses. Some shops may have thicker "cubic stone" remnants you could pick up at a reasonable cost too. Blue Pearl is my favorite granite color, but Galaxie Black or Black Pearl looks good too if you want a darker color.
Try these; I got a very solid 3" base for the TT from them. Looks great.
http://www.timbernation.com/pcake_popup.cfm_________________________________________________
SolidSqual wrote: »My other thought was to go to Home Depot and buy these solid cutting boards made of some very rich wood that weighs about 30lbs for $40 bucks a piece.
Yeah, do this and save plenty of dough. Just buy some heavy duty spikes from PE and you're done.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=240-718
If you don't want to DIY, try a modular shelf like this one:
http://www.racksandstands.com/VTI-BL404-VI1001.html
You can use the individual shelves as amp stands or you can stack them.
HT's suggestion to go with Timbernation is a very good one, too. I've bought a few items from them.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
DIY'd one last night...well the scrap aircraft aluminum was a buck a pound, but the stainless bottle stoppers were $4 for 3@ Big Lots.
You could try various laminations ,maple ,a slate insert,bamboo cutting board, mdf...arcrylic.
The floor-spike protecters are cut down 30/30 brass
Wow; you could make a living out of those stands....great job!!_________________________________________________
Music Joe isn't a half assed audionut....he's completely in the bag. Great work.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Nervous energy and a penchant for recycling...I'll be the audionut pushing the shopping cart with a stereo strapped to the handle.
My god! That is gorgeous. I wish I had your tools and talent.
Soooooooooooooo, we all want to know. Me next. LOL
very nicely done or just say SSSWWWEEEEEEEEEEEEEEEEETTT.engtaz
Now
Im just sayin ---
But I could build that Salamander stand for like half the price -- lol
All that thing is is a board with four spikes
Man they are BANKING- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yeah, I decided to go the DIY route. I just bought some cherry cutting boards from Lowes that are 37 pounds a piece and 2.5" thick. Parts express is sending me some spikes.
