Hey Ron-P
CHRIS
CHRIS Posts: 454
Ron,
Remember a while back (several months) I was talking with you about some how useing stuff like the thick rubber jar openers are made of for dampening vibrations. I finally found it. You can get rolls of it at RV centers. They use it on shelves to stop dishes and things from moving while driving. Its pretty cheap too plus you can cut to fit. I put a peice on top of my DVD players with a 5lb lifting weight on top it. It made a noticeable difference in the video portion of the players. The pre-amp is next, I think the amps can hold their own.
Chris
Chris :)
  • Ron-P
    Ron-P Posts: 8,520
    edited November 2001
    Sweet. There is an RV shop a few miles from my house. Gonna hav'ta go in a check it out. Thanks for the heads up:)
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • Aaron
    Aaron Posts: 1,853
    I have a feeling that Ron is going to go nutso with this stuff. The next time I pop on over to the Green Room all of the speakers, components, and big screen will be covered with this stuff! :D
    Aaron
  • Ron-P
    Ron-P Posts: 8,520
    What'er ya say'in Aaron, Huh? Lets take it outside, C'mon lets go, you-n-me pal, mono-e-mono.
    I'll try anything (excluding other men) once.
    Have you seen my Favorites page I just began building today? Ohhhhh Yeahhhhhhh:)
    Peace Out~:D
    If...
  • hoosier21
    hoosier21 Posts: 4,420
    Nice webpage additions, where can you buy that beer at? is it locals only?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
