Bi-wiring LSI-15's
Has anybody tried Bi-wiring LSi-15's and if so, do you notice a difference?
Thanks.
Thanks.
Post edited by Dave38 on
Yes and No. Replace the stock jumpers with some good quality wire, and you'll be golden.
Thanks for the response. So you are saying that by replacing the stock jumper with high quality wire, that would be an improvement? Interesting info.
What wire is recommended?
Thanks. -
The stock jumpers on the 15's are nothing to brag about. 12g wire from whatever company you choose will be an improvement, IMO. I personally use jumpers from cobalt cable, they look nice and come terminated. If you'd like to save a few bucks, belden wire from BJC will do just fine.
Are those the 6" jumpers? I may order 4. Thanks. -
Thanks, Mike.
